Toymods » Tech & Conversions » ae86 Diff con. (strength?)
45aken
NSW.south coast.Drifting
icon2.gif  ae86 Diff con. (strength?) Tue, 31 May 2005 07:53 Go to next message
hello all,
just wondering if the t-18 diff with a good LSD will hold up to CA18det power (looking at around 160-200kw ATW)? or am i better off going for something bigger? if so what?
i have searched, but there is limited results to do with strength.
ae86drift
sydney.au
Re: ae86 Diff con. (strength?) Tue, 31 May 2005 08:42 Go to previous messageGo to next message
simon is a result of a t18 t series diff with a TRD centre
he had his ca18det caining that setup for ages in drift comps ect.
and its STILL going.
the diff life has a lot to do with your style of driving.
monkeymajik
Re: ae86 Diff con. (strength?) Tue, 31 May 2005 08:45 Go to previous messageGo to next message
If you are not taking it out to willobank and dumping it at 5grand on the 1/4 every weekend you should be right.
45aken
Re: ae86 Diff con. (strength?) Tue, 31 May 2005 08:58 Go to previous messageGo to next message
i will race it sometimes, but it should be sweet.
just one question, and this might sound stupid, but i have never blown a diff before:
if i buy a $1k LSD and blow my diff, did i blow the 1K LSD or something else? or can it be either?
monkeymajik
Re: ae86 Diff con. (strength?) Tue, 31 May 2005 09:12 Go to previous messageGo to next message
Depends...you could screw the center or you could just spin the axle. Most T series diff damage I have heard/seen is twisted axles.
45aken
Re: ae86 Diff con. (strength?) Tue, 31 May 2005 09:19 Go to previous messageGo to next message
so if the axle twists, can i still use the LSD?
EVOSTi
cambo
      no
Re: ae86 Diff con. (strength?) Tue, 31 May 2005 10:52 Go to previous messageGo to next message
yep.
it is all about driving style like stated. im running the stock s series diff, hada gze for over a year and now around 200RWKW's with the turbo set up and the diff doesnt even make so much as a noise. its all about how you drive it.
shcao
Re: ae86 Diff con. (strength?) Tue, 31 May 2005 10:56 Go to previous message
if you blow the diff up, you can rebuild em.
rebuild kits only cost about 300..
and you got a brand new diff!
Previous Topic:AE101 MAP GZE Supercharger shutting off after 5,500rpm - fixed
Next Topic:MA70 >> JZA70 begins
Current Time: Tue Oct 20 03:58:57 UTC 2026
Total time taken to generate the page: 0.0046150684356689 seconds
