Classifieds » Car/Engine Electronics & Audio » FS: Subs/Amps/Speakers/HU
oRiCLe
April 2005
FS: Subs/Amps/Speakers/HU Tue, 31 May 2005 12:00 Go to next message
Okay, time to sell all my car audio equipment and start a fresh as I am selling my car to make way for a new toy
If you are interested in anything below, you can email at athorp@gmail.com and we can sort something out. Cheers peeps ;P
pickup can be arranged in Sydney, postage is available at buyers expense
Kenwood KDC-MP4020 MP3 Head Unit
http://gallery.as-tech.com.au/albums/CarStereo/nor mal_CarStereo%20012.jpg
General Features
- TDF (Theft Deterrent Faceplate)
- Dot Matrix Multicolour Wide LCD with White LED Backlight
- TV Control with VZ-7000P
- Key Illumination (Green)
- Digital Clock (24H)
- DAB Ready with Optional Unit (KTC-9090DAB)
- Supplied with Remote Control Unit (10-key)
Audio Features
- Maximum Output Power: 50W x 4 (MOSFET Power IC)
- 1 Preout
- System Q: Sound Control with Pre-programmed Tone Curves
- Separate Bass/Mid Range/Treble Control & Source Tone Memory
- AUX Input with Optional Unit (CA-C1AX or KCA-S210A)
- Fader & Loudness Control
- Attenuator (-20dB) with Smooth Volume Return
- Single CD Features
- MP3 Decoder with ID-3 Tag Display
- CD Text Ready
- CD-R/CD-RW Compatible
- Random/Repeat/Scan Play
- Changer Control Features
- Dual Disc Changer Control Capability (CH1/CH2 & AUX)
- DNPS (Disc Name Presets) with Compatible CD Changers
- DNPP (Disc Name Preset Play) by Remote
- CD Text Ready with Compatible CD Changers
- Direct Access with Remote
- Random/Repeat/Scan Play (Disk/Track)
Tuner Features
- FM/AM 24 Station Presets (18FM. 6AM)
- AME (Automatic Memory Entry)
- Up/Down Seek Tuning
- Selectable Channel Spacing
- SNPS (Station Name Presets)
Price When New (Aus$): 499.00
great condition, no scratches etc.
$150 ono <-- SOLD
_____
Avantgarde 27dxi 1000 Watt Max 2 Channel Competition Series Amplifier
http://gallery.as-tech.com.au/albums/CarStereo/nor mal_CarStereo%20019.jpg
http://gallery.as-tech.com.au/albums/CarStereo/nor mal_CarStereo%20025.jpg
- 2 x 167 Wrms
- 2 ohm stable
- 6/12db Bass Boost setting
- approx 600Wrms @ 2 ohm Mono
great working condition, no scratches etc.
$150 ono
_____
Jaycar (Response) 2x100wRMS 2 Channel Amp
http://gallery.as-tech.com.au/albums/CarStereo/nor mal_CarStereo%20026.jpg
http://gallery.as-tech.com.au/albums/CarStereo/nor mal_CarStereo%20027.jpg
- 2x100wRMS
- 1x234wRMS @ 4 ohm
good working condition also, no scratches etc.
$120 ono
_____
Kenwood KFC7189ie - 320w 4-Way 7x10" Speakers
http://www.lowcostcaraudio.co.uk/images/products/s tandard/68.jpg
http://gallery.as-tech.com.au/albums/CarStereo/nor mal_CarStereo%20029.jpg
http://gallery.as-tech.com.au/albums/CarStereo/nor mal_CarStereo%20031.jpg
- 7x10 inch Speakers
- 320W 4-Way Speakers with Pearl Mica Woofers
- PEI Cone Midrange
- Balanced Dome Tweeters & Dome Super Tweeters
- Image Enhancers
- 320w Max, 80w RMS
great condition, taken care of, not driven hard, used for rear fill
$120 ono
$200 for the 7x10s and jaycar amp (they are an even match of power)
_____
Sony 12" 1200W Subwoofer in Sony Sub Box
http://gallery.as-tech.com.au/albums/CarStereo/nor mal_CarStereo%20034.jpg <-- This box
http://gallery.as-tech.com.au/albums/CarStereo/nor mal_CarStereo%20038.jpg <-- This sub
http://gallery.as-tech.com.au/albums/CarStereo/nor mal_CarStereo%20039.jpg
(NOTE: THE OTHER SUB IS NOT FOR SALE.)
- In-Car Measured SPL (peak @ 50 Hz): 1 watt: 105.1 dB; 350 watts: 127.6 dB; 1200 watts: 130.3 dB
- Published Specs: XS-L121P5
- Max Power (W): 1200
- Max Power (RMS, W): 350
- Sensitivity (dB/W/m): 89
- Freq. Resp.: (Hz) 18 - 2k
- Impedance (Ohms): 4
- D (mm): 250
- D (inch): 9.8
- Rdc (Ohms): 3.2
- Fs (Hz): 26.4
- Qts: 0.42
- Qes: 0.44
- Qms: 5.86
- Vas (Lit.) : 55.5
- Vas (ft_): 1.96
- Mms (g) : 219.0
- Lvc (mH) : 1.2
- Xmax (mm) : 7.5
- Xmax (inch) : 0.3
- BL (Tm) : 16.1
- General Info: 12-inch Polypropylene Cone
- Weight: 12 pounds 10oz
- Mounting Diameter: 11.0 inches
- Mounting Depth: 6.375 inches
- Unique pentagon cone design.
- Gold-plated Binding Posts.
- Small sealed/ported enclosure optimized.
box has slight scuffs of carpet back to the wood, sub is in perfect condition
$150 ono <-- Negotiating sub only, box still available at this point
$250 for package with sub, box and Avantgarde amp
_____
Sansui SM-A500 70wx2 Channel Amp
http://gallery.as-tech.com.au/albums/CarStereo/nor mal_CarStereo%20043.jpg
http://gallery.as-tech.com.au/albums/CarStereo/nor mal_CarStereo%20047.jpg
http://gallery.as-tech.com.au/albums/CarStereo/nor mal_CarStereo%20049.jpg
- 2x35wRMS
- Low pass filter
great amp for running those rear 6" or front speakers with
good condition
$50 ono
_____
[Updated on: Thu, 02 June 2005 11:46]
TRU32U
Re: FS: Subs/Amps/Speakers/HU Tue, 31 May 2005 14:49 Go to previous messageGo to next message
where about in syd are you
oRiCLe
April 2005
Re: FS: Subs/Amps/Speakers/HU Wed, 01 June 2005 04:34 Go to previous messageGo to next message
can organise pickup in bankstown, campbelltown, penrith, hills district or camden/picton areas
TRU32U
Re: FS: Subs/Amps/Speakers/HU Wed, 01 June 2005 15:06 Go to previous message
pm me ur contakt
Previous Topic:WTB: SAFC2 Apexi stand
Next Topic:"SOLD" GReddy Full Auto Timer(Turbo Timer)
Current Time: Sat Oct 17 17:07:57 UTC 2026
Total time taken to generate the page: 0.0053379535675049 seconds
