Toymods » Tech & Conversions » T50 won't slide off engine
ae86slaver
T50 won't slide off engine Wed, 01 June 2005 03:24 Go to next message
The bastard won't come off Confused
I've double, trippled, 100led checked that all bolts are off, gearbox crossmember is unbolted, all ancilleries are off - starte/clutch cyl. but the thing is so attached and stubborn
any tips?
i've tried chisel, hammering it, kicking, jacking it up and down etc
help Crying or Very Sad
Re: T50 won't slide off engine Wed, 01 June 2005 03:28 Go to previous messageGo to next message
Normally I just stick a big screw driver in between the bellhousing and block and just wedge it out.
AEeightysix
Baulkham Hills, Sydney
Re: T50 won't slide off engine Wed, 01 June 2005 03:29 Go to previous messageGo to next message
Did u get that bolt right at the top of the gearbox near the heater hoses.
That can be a bastard to find sometimes
U need a HUGE extension to get that 1!
Come round and have a look at my gbox to see where all the bolt holes r if ur stuck.
Just keep tryin des Laughing
ae86slaver
Re: T50 won't slide off engine Wed, 01 June 2005 03:30 Go to previous messageGo to next message
i got that bolt, it was being a prick too, i couldn't find my 17mm so i had to go and buy one Confused but still it won't come off
hmm, *goes and wedges screwdriver again*
ke382TG
Re: T50 won't slide off engine Wed, 01 June 2005 03:38 Go to previous messageGo to next message
Make sure you are supporting the weight of the gear box completely as you try to slide it off. Any lateral force on the spigot shaft caused by the "hanging" of the gearbox will cause it to bind and not want to move at all.
Trust me I have done a lot of T50 boxes in and out of the car and the W boxes a few times. T50's are very light and easy as pie to remove/fit.
Good luck, and make sure no bolts are still holding it on Laughing
No No No No No No
[Updated on: Wed, 01 June 2005 03:39]
ae86slaver
Re: T50 won't slide off engine Wed, 01 June 2005 03:46 Go to previous messageGo to next message
haha by that i mean i tried to pry it with a chisel, and also tried hammering the box in different spots to remove it
takai
Re: T50 won't slide off engine Wed, 01 June 2005 03:50 Go to previous messageGo to next message
The AE86 engines had a pair of stays on the bottom of the engine block which connected to four bolts on the front side of the engine.
ae95
Re: T50 won't slide off engine Wed, 01 June 2005 04:04 Go to previous messageGo to next message
hmm
cant say i've ever had this problem
id say there would be some bolts still in there.
u taken the starter motor out?
shifter?
ke382TG
Re: T50 won't slide off engine Wed, 01 June 2005 04:17 Go to previous messageGo to next message
Maybe the metal pole coming out of the gearbox and attached to the thing at the back of the car that makes the wheel turn is still attached and is inhibiting the sliding action Laughing
Sorry, couldn't help it Embarassed
Perhaps you can fix it with fireworks! (Remember that classic Simpsons episode Laughing )
styler
delete me
[Updated on: Wed, 01 June 2005 04:19]
styler
Re: T50 won't slide off engine Wed, 01 June 2005 04:18 Go to previous messageGo to next message
iv heaved and hoe'd to get mine out too with no luck once or twice, once was starter motor left in and the other time was a devious hidden bolt, i undid them and it slid out nice and easy when supported properley. i feel the frustration Laughing cant say i have had one jam on me though. the shifter is the only other item theat could jam it as mentioned.
[Updated on: Wed, 01 June 2005 04:20]
ae86slaver
Re: T50 won't slide off engine Wed, 01 June 2005 04:37 Go to previous messageGo to next message
ok it's out Razz Embarassed Laughing
styler
Re: T50 won't slide off engine Wed, 01 June 2005 07:16 Go to previous messageGo to next message
and the problem was? Razz
nudes
Sydney/Wollongong
Re: T50 won't slide off engine Wed, 01 June 2005 07:35 Go to previous messageGo to next message
I've got $10 on shifter..
ae86slaver
Re: T50 won't slide off engine Wed, 01 June 2005 07:39 Go to previous messageGo to next message
LOL
The weight of the gearbox, as ke382TG suggested, i jacked it up horizontally and got into kung fu position Razz
TE72_Turbo
Re: T50 won't slide off engine Wed, 01 June 2005 07:50 Go to previous messageGo to next message
Razz good work
Did you bust a gearbox with the newfound power of the turbo setup??
ae86slaver
Re: T50 won't slide off engine Wed, 01 June 2005 14:54 Go to previous messageGo to next message
clutch Confused
gearbox is next tho, it's on its last legs Embarassed
ae86drift
sydney.au
Re: T50 won't slide off engine Wed, 01 June 2005 15:34 Go to previous messageGo to next message
hehe
good one des. Wink
Big T
Re: T50 won't slide off engine Thu, 02 June 2005 12:05 Go to previous messageGo to next message
Time for a w5* upgrade then eh? Very Happy
TE72_Turbo
Re: T50 won't slide off engine Thu, 02 June 2005 12:08 Go to previous messageGo to next message
sounds like it!
AEeightysix
Re: T50 won't slide off engine Sun, 05 June 2005 06:16 Go to previous message
pm sent regarding the clutch prob...
Previous Topic:Corona Mk2 Conversion
Next Topic:3s gte RWD stuff
Current Time: Tue Oct 20 15:56:11 UTC 2026
Total time taken to generate the page: 0.0063149929046631 seconds
