Toymods » Tech & Conversions » 4agze knock sensor options
wiso
4agze knock sensor options Wed, 01 June 2005 06:55 Go to next message
G'day just wondering does anybody know if any other type of knock sensors can be used on a 4agze? can a 7mgte one be used instead, or maybe 3sgte ones? I don't really car about the plug fitting, I can always make that fit one way or another. but more the internals or signal it sends out? would prefer same hread size though as I have just drilled the block to fit this one?
Actually I should ask first is there any way to test if a knock sensor is stuffed? I get the error code on the ecu, and when installing I knocked it pretty hard by accident, so i am guessing I did some damage to it.
If anybodys knows please let me know, I have dones searches but came up with nothing on the particular question.
Phoenix01
Brisbane, Australia
Re: 4agze knock sensor options Thu, 02 June 2005 02:53 Go to previous message
Well.. If ur knock sensor is stuffed. You'll lose power, especially over 5,500rpm (i lost 20kw). It will cause the car to run super rich, and it will shut the supercharger off after 5,500rpm.
Previous Topic:Adjusting clutch pedal height (TA22)
Next Topic:Soarer door lock mechanism
Current Time: Sat Oct 17 23:02:20 UTC 2026
Total time taken to generate the page: 0.0034949779510498 seconds
