Toymods » Tech & Conversions » 4age skipping a beat
4agerolla
Sydney.. North Shore
May 2005
4age skipping a beat Wed, 01 June 2005 10:35 Go to next message
here is my problem.. my 4age will occasionally cut in and out, only once at a time and then the engine check light will light up for a few seconds.. it will only do this when not 100% warm and when you give it a bit of a rev...
if anyone has any help it will be much appreciated!!
chris
towe_001
Somewhere on a dirt bowl ...
Re: 4age skipping a beat Thu, 02 June 2005 08:30 Go to previous messageGo to next message
To me it sounds like an ignition fault.
Have you had a look at the plugs and made sure that the leads sitting firmly on the coil, dizzy and plugs.
How about the dizzy connectors, are they ok.
What about the coil.
FKN16V
NSW, East Coast
Re: 4age skipping a beat Fri, 03 June 2005 08:27 Go to previous messageGo to next message
Have you tried to find any error codes on the ecu, id start there.
Steve
Re: 4age skipping a beat Fri, 03 June 2005 11:31 Go to previous messageGo to next message
Crank agle sensor a bit unhappy? Or maybe the wiring to it?
FKN16V
NSW, East Coast
Re: 4age skipping a beat Fri, 03 June 2005 21:36 Go to previous messageGo to next message
mrshin wrote on Fri, 03 June 2005 21:31
I wasnt aware 4ag's had a crank angle sensor, uless it been modified.
Steve
4agerolla
May 2005
Re: 4age skipping a beat Sat, 04 June 2005 01:26 Go to previous messageGo to next message
its leaking a bit of oil out of the dizzt cap.. could that be related?? i dont know that much about engines so any help is much appreciated!!!! Very Happy
4agerolla
May 2005
Re: 4age skipping a beat Sat, 04 June 2005 01:27 Go to previous messageGo to next message
by dizzt i meant dizzy.......
4agte
Toronto, Downtown
Re: 4age skipping a beat Sat, 04 June 2005 01:47 Go to previous messageGo to next message
could be oil in the dizzy but i would say as mentioned above to look up ecu error codes in google and short the 2 pins in your diagnostic plug with a paper clip i cant rember which ones you have to short e1 and f1 or something like that and see if it spits out an error code.
Start from there is that fails check your plugs leads etc.
4agerolla
May 2005
Re: 4age skipping a beat Sat, 04 June 2005 14:36 Go to previous message
ok cool ill give that a try.. cheers
Previous Topic:gen1 3sge vacuum hose diagram
Next Topic:Tuning ems stinger to a 20v ae86.
Current Time: Sat Oct 24 09:10:52 UTC 2026
Total time taken to generate the page: 0.0057029724121094 seconds
