Toymods » Tech & Conversions » 1g-gte versions
gabe
1g-gte versions Thu, 28 November 2002 04:32 Go to next message
just wondering if the 185hp 1ggte is essentially the same engine as the 210hp 1ggte aside from the intercoolers??
Re: 1g-gte versions Thu, 28 November 2002 04:57 Go to previous messageGo to next message
They have a different ECU and later versions run higher boost too.
Bugman
Re: 1g-gte versions Thu, 28 November 2002 05:14 Go to previous messageGo to next message
different injectors aswell??
gabe
Re: 1g-gte versions Thu, 28 November 2002 05:57 Go to previous messageGo to next message
if i have the 185hp with a few mods could i turn it into a 210 hp 1ggte?? or is it not worth it??
its in a ra23 by the way
Bugman
Re: 1g-gte versions Thu, 28 November 2002 06:17 Go to previous messageGo to next message
well you could just up the boost.
as this differs from version to version.. I think that is the main contributer to the HP variations. the 210 version is at 10.5psi
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
icon4.gif  Re: 1g-gte versions Thu, 28 November 2002 23:53 Go to previous messageGo to next message
The difference isn't just in the intercoolers.
Gen 2 got bigger injectors and bigger piping into and out of the turbo.
Gen 3 got a much more aggressive ECU.
They're big differences which make each consecutive generation capable of making more power with the same mods... ie: a Gen 3 at 14psi will make ~151kW while a Gen 2 at 14 psi will make 144kW or so.
Not sure of the differences once you start changing things like turbos and ECUs. But it's always safest to start from the best base (Gen 3).
Helmann
Ipswich
Re: 1g-gte versions Fri, 29 November 2002 02:40 Go to previous messageGo to next message
OK I have a queer one. My 1g-gte (front mount intercooler) has injector colour and ecu colours different from what the guide on this site has. I have yellow ecu connector but grey and brown injector connectors.
Any ideas???
How many ponies i got????
What psi would mine be running at?
Oh and it is from an 88 soarer. There was even a little factory piece of paper behind the dash that had all the engine details on it and it said it was 210 hp.
I got no idea.
[Updated on: Fri, 29 November 2002 02:43]
1G-GTEFreAk
Re: 1g-gte versions Fri, 29 November 2002 03:37 Go to previous messageGo to next message
Hey you guys
I would like any and everybody to reply to this
One I have a 1G-GTE engine in a 1990 toyota Chaser
I want to add on a power Extreme tuned exhaust from Trust-power
what else shpuld I do to get more power from the 1G-GTE and is there a way to avoid fuel cut off from the ecu through sinple inexpensive modifications,aslo
will a 3.0 fuel pump help in the upgrades seeing that the engine is basically 2.0l
also where on earth can I get aftermarket plug wires for this engine.
Any body please respond
Re: 1g-gte versions Fri, 29 November 2002 03:54 Go to previous messageGo to next message
A bigger fuel pump won't increase performance unless the existing one isn't up to the task, and if that was the case your engine would probably be toast by now. Most Toyotas have much larger pumps than they really need (eg Mk4 Supra pump is good for up to 600hp apparently) so you have plenty of headroom for mods before you have to upgrade it.
Nark
Cabramatta, NSW
Re: 1g-gte versions Fri, 29 November 2002 04:17 Go to previous messageGo to next message
Helmann, no idea dude. Bring your car to the next dyno day. Very Happy
1G-GTEFreAk, what size is your exhaust? How much boost you running? For spark plug leads, try Magnecor. They're one of our sponsors so check the sponsors section for more details.
Helmann
Ipswich
Re: 1g-gte versions Sun, 01 December 2002 04:31 Go to previous messageGo to next message
When is the next dyno day in brisbane?
Nark
Cabramatta, NSW
Re: 1g-gte versions Mon, 02 December 2002 00:05 Go to previous messageGo to next message
Err... You might have to wait for a while... Very Happy
punkdefender
Dandenong/VIC
Re: 1g-gte versions Fri, 14 February 2003 20:56 Go to previous messageGo to next message
I currently have a 1g-gte gen 1, would I be able to swap just the gen 3 engine straight over without changing the ecu?
gold28
Madrid - Spain
Re: 1g-gte versions Mon, 17 February 2003 02:38 Go to previous message
Helmann
By memory, my 1G has yellow ECU and Grey injector plugs, It is pretty much stock, except for 2.5in mandrel exhaust and pod type filter. It put out 111kw at the wheels.
punkdefender
Nup.....You will have heaps of problems as most of the plugs on the wiring harness won't fit.
Previous Topic:Supercharger vent VSV???
Next Topic:2JZ-GTE into MX83 Cressida - any info/assistance
Current Time: Fri Nov 20 11:57:59 UTC 2026
Total time taken to generate the page: 0.0071618556976318 seconds
