| Author | Topic |
Re: New DBA slotted discs for AE86
Wed, 01 June 2005 13:19
can they be fitted as replacement to the stock DRUMS as well as upgrade to the discs? im interested. in sydney btw
Wed, 01 June 2005 13:30
Are these just the ones from the DBA catalogue or are they custom made? Dimensions?
Wed, 01 June 2005 14:12
suit front or rear? stock size or what?
Wed, 01 June 2005 14:17
@ noobs, they are DISK ROTOR's they will only fit a disk brake setup, that is the FRONT ONLY of a toyota sprinter.
Wed, 01 June 2005 14:18
The disk brake rear end has solid disks
Wed, 01 June 2005 14:27
| chrisellis wrote on Thu, 02 June 2005 00:17 | @ noobs, they are DISK ROTOR's they will only fit a disk brake setup, that is the FRONT ONLY of a toyota sprinter.
unless u have a disc brake rear end
kthxbye
Thu, 02 June 2005 01:32
They are a direct replacement for the front of an AE86. they are the same size as standard but are solid and slotted.
These are for pick up in Sydney area only (forgot to mention earlier)..... Sorry.
Thu, 02 June 2005 08:00
what brand are they?
Thu, 02 June 2005 08:34
it says DBA dude
Thu, 02 June 2005 10:42
These available in vented? As "upgrade" from teh standard vented discs.
Vented/ slotted JAY DEE EMM rotors.
Thu, 02 June 2005 11:35
unfortunately they are not avaliable in vented which is why they won't fit on my car (i think i have the import brakes) the solid discs are 12.5mm thick where as the vented ones are about 18mm.
Fri, 03 June 2005 13:51
quick question,
how much am i looking at to upgrade the drums at the back to discs. if i upgrade the front i'll upgrade the back also, and i aint "upgrading" to fully hectic drums... anyone know a ball-park figure? my 86 is my daily driver so locking up the front and having the back swing around all the time wouldn't be smart on the road
Fri, 03 June 2005 14:17
| pLaYa_OnE wrote on Fri, 03 June 2005 23:51 | quick question,
$1000. Disk to disk t-series open diff.
Fri, 03 June 2005 16:04
| pLaYa_OnE wrote on Fri, 03 June 2005 23:21 | quick question,
on a light car, drums arent bad at all, being a street car it definitely wont be bad or (lock up the front) etc
jap rear discs are pretty small anyway, the difference would be illegable, once u did a few repeated stops then the discs would be better
many people have to fiddle with the bias so the rears actually work ahhahaha
it is very costly for small results
im all for discs but dont come back complaining when your hand brake doesnt do fully sik skids!
Sat, 04 June 2005 01:13
Rear discs are a waste of money.
As are these poo slotted discs. $140 each for non vented WHATS THE POINT. They will cook in no time.
Sat, 04 June 2005 03:58
cook like arches w33d all up in his pipe
Sat, 04 June 2005 13:59
thanks for the advice truenosedan. I can't afford to upgrade my brakes at all at the moment anyway, big cost for small difference is even more reason not to bother. cheers
Mon, 06 June 2005 08:44
Or you could use the diff out of a celica RA60 cause it fits strait in, all you have to do is get the tailshaft adapted and there you go.. instant disc brake upgrade (pity about the open center though).
This is what I have in my AE86 and it works fine. A brake upgrade was required cause of the substantial power increase with the engine transplant.
Tue, 07 June 2005 06:12
whats the part # on these rotors... didnt DBA actualli made slotted rotors for an 86
Tue, 07 June 2005 06:13
oops typo... didnt think DBA actualli made slotted rotors for an 86
