Toymods » Tech & Conversions » couple of questions about my car
tomee
melbourne, australia
couple of questions about my car Wed, 01 June 2005 22:38 Go to next message
ok guys just a couple of questions...
what causes the light vibration in the steering wheel when at idle and not moving?
my steering wheel has light vibration when stopped at the lights..
but when put in neutral the vibration goes away.
is it something to do with the gearbox? sutffed?
also i have a noisy compressor bearing, anyone else replaced or got this reco'd?
ive heard its a big job as it depends which bearing. pretty sure it might be for the air con, so they might have to open it up and re-gas it???
the car in question is a 96 V6 camry
any help greatly appreciated
Dust
Re: couple of questions about my car Thu, 02 June 2005 04:24 Go to previous messageGo to next message
you may have answered your first question with your second question.
tomee
Re: couple of questions about my car Thu, 02 June 2005 06:59 Go to previous messageGo to next message
really?
i only thought it was just noisy...
so it might be at fault of the vibrations?
how so??
anyone know the approx cost of getting this replaced?
decoyslikecurves
Re: couple of questions about my car Fri, 03 June 2005 07:12 Go to previous messageGo to next message
sound is directly related to vibration.
IE its caused by vibration
Celica_John
Re: couple of questions about my car Fri, 03 June 2005 11:55 Go to previous messageGo to next message
i always notice less 'vibrations' when idling at a set of lights after i've replaced the dizzy cap and rotar button.
if you haven't changed them in a yr give that a go!
Celica_John
Re: couple of questions about my car Fri, 03 June 2005 11:56 Go to previous messageGo to next message
and also check to see if your idle is set to the manufacturers guildlines.
tomee
Re: couple of questions about my car Sat, 04 June 2005 02:42 Go to previous messageGo to next message
ive just cahnged the spark plugs and leads last night
whats a rotar button?
kwayzivietnamese
Re: couple of questions about my car Sat, 04 June 2005 03:03 Go to previous messageGo to next message
how bad is the vibration?
If its not too bad then yeah prob cause by a/c.
If its bad, could be other problems.
ra_28
Re: couple of questions about my car Sat, 04 June 2005 03:06 Go to previous messageGo to next message
What is the car idling at in neutral compared to in drive?
[Updated on: Sat, 04 June 2005 03:07]
tomee
Re: couple of questions about my car Sat, 04 June 2005 05:12 Go to previous messageGo to next message
the vibration is light...
id say around 50% less than say a mobile vibrating...
ra_28. the car idles the same speed when put in Neutral.... ill double check tonight, but im pretty sure its the same
Celica_John
Re: couple of questions about my car Sat, 04 June 2005 06:29 Go to previous messageGo to next message
The dizzy cap is the thing that the other side of the leads connect to. once you take the dizzy cap off (usually 2 screws/bolts or clips) you'll see the rotor button. it's like a plastic tee shape thing. just pull it right off. no screws or anything.
Bobski
Re: couple of questions about my car Sat, 04 June 2005 07:33 Go to previous message
increse idle rpm....
Previous Topic:AW11 MR2 + AE86 Same Mainfold?????
Next Topic:AE86 into TA22
Current Time: Thu Oct 15 22:54:19 UTC 2026
Total time taken to generate the page: 0.091746807098389 seconds
