Toymods » Tech & Conversions » Mixing Auto Tranny Fluid
Mixing Auto Tranny Fluid Thu, 02 June 2005 01:30 Go to next message
We are about to change the tranny fluid on my dads Prado.
Its a '98 model, and I presume its running Dexron 3 (good assumption? whatever it had from factory anyway, A340F I think)
Anyhoo, we are going to put Type IV in it.
Is it ok to mix Dexron 3 and Type IV?
Obivously we are going to drain the pan, fill it up, drive for a bit, repeat until we run out of fluid.
How much should I buy? 8L? 12L?
When should I put the new filter on? On the last change or the first?
We don't mind doing this, but would we be better off to get an auto transmission place to do it for us?
[Updated on: Thu, 02 June 2005 04:53]
Re: Mixing Auto Tranny Fluid Thu, 02 June 2005 04:53 Go to previous messageGo to next message
Ok, done some digging for those interested.
If the Dipstick/sump plug says DII or DIII use Dexron 3.
If it says TII, TIII or TIV, use Type IV.
Don't put Type IV in a tranny that wants Dexron 3.
Simple!
As for flushing it, drain the pan, fill up, drive.
Repeat until drain is clean.
Then clean catch tray, drain pan, drop pan, change filter, reinstall pan, replace fluid from catch tray.
Simple!
Chris Davey
sunny coast, qld
Re: Mixing Auto Tranny Fluid Thu, 02 June 2005 06:02 Go to previous message
thanks mate Smile
Previous Topic:attach a blowoff valve
Next Topic:1ggze info required
Current Time: Mon Nov 23 15:03:51 UTC 2026
Total time taken to generate the page: 0.0038530826568604 seconds
