Toymods » Tech & Conversions » W58 to 1J.can I use an R154 fly.clutch.custom p.p.????????
manmx83
W58 to 1J.can I use an R154 fly.clutch.custom p.p.???????? Thu, 02 June 2005 15:47 Go to next message
Yeah,I am having trouble getting the na 2j flywheel required to fit w58 to 1j and will end up with a spare 1j r154 flywheel,clutch and p.plate so I wondered if it may be possible to utilise the flywheel and clutch from the R154 set up with a p.plate [unknown] to suit fitment of the w58.
Being aware R154 is pull clutch and W58 is push and different bolt pattern for p.plate to flywheel.Still it may be easier to sort a p.plate to do the job rather than chasing the 2j fly at $250 plus.
Any info appreciated.Cheers.Pete. Smile
Re: W58 to 1J.can I use an R154 fly.clutch.custom p.p.???????? Thu, 02 June 2005 22:14 Go to previous messageGo to next message
Try taking your flywheel to a good clutch shop (eg Direct Clutch) and see if they can help you.
Or you could wait a few weeks and buy my 2JZ-GE setup... flywheel, bellhousing and ceramic 5-puck clutch. It's no good to me when the V161 goes in. Very Happy
MR 1JZ
Re: W58 to 1J.can I use an R154 fly.clutch.custom p.p.???????? Fri, 03 June 2005 01:38 Go to previous messageGo to next message
pete
I enquired about this when I did my 1JZ conversion, extreme clutch make a clutch and pressure plate to do the job but you need to get the 1JZGTE R154 Flywheel modified to handle it or source a 2JZ NA flywheel(which you obviously already know) the clutch plate and pressure plate are useless as the splines on the clutch plate are different and the pressure plate is a pull type, getting the flywheel modified I was quoted at around $200, and if its already been machined a couple of times or more you cant modify it as they will have to take too much off of it do make it compatible.
Id just get the 2JZGE NA flywheel norbs has on offer or go for an R154...modifying stuff isnt worth it
manmx83
Re: W58 to 1J.can I use an R154 fly.clutch.custom p.p.???????? Fri, 03 June 2005 15:50 Go to previous messageGo to next message
Thanks guys,Norbie you will be selling that gear as a package I imagine.I have a bellhousing and want a stock clutch to keep load off the w58.Dont want to be replacing boxes.Have been offering 250 for a flywheel [na 2J] but no luck as yet.cheers.Pete. [I have time on my side] Smile
manmx83
Re: W58 to 1J.can I use an R154 fly.clutch.custom p.p.???????? Fri, 03 June 2005 15:58 Go to previous messageGo to next message
add this up
300 bellhousing
250 flywheel
500 gearbox
its bullshit and people say R154's are expensive Mad
the way to go is a complete 2J set up at $1000 or so,seems cheaper buying a bit at a time but it aint......
ed_ma61
Lost in the K hole
Re: W58 to 1J.can I use an R154 fly.clutch.custom p.p.???????? Sat, 04 June 2005 11:43 Go to previous messageGo to next message
Norbie wrote on Fri, 03 June 2005 08:14
ahem... 'dibs' !! Laughing
ed
Re: W58 to 1J.can I use an R154 fly.clutch.custom p.p.???????? Sat, 04 June 2005 11:51 Go to previous messageGo to next message
I hadn't forgotten about you Ed. Razz
Are you coming up next weekend?
BlackSupra
Re: W58 to 1J.can I use an R154 fly.clutch.custom p.p.???????? Sat, 04 June 2005 11:53 Go to previous messageGo to next message
Norbie wrote on Sat, 04 June 2005 21:51
Ed is a woman, i doubt he would come up.
ed_ma61
Lost in the K hole
Re: W58 to 1J.can I use an R154 fly.clutch.custom p.p.???????? Mon, 06 June 2005 11:54 Go to previous messageGo to next message
BlackSupra wrote on Sat, 04 June 2005 21:53
yeah, i could be a wonman, or i could be in germany instead...
damn, i had some cool photos to show off from the F1, but i cant seem to work this dumb german photopaint edit thingo No No No
ed
twinturbo86
Re: W58 to 1J.can I use an R154 fly.clutch.custom p.p.???????? Tue, 07 June 2005 01:12 Go to previous messageGo to next message
if u still cant find a flywheel
dellow automotive make flywheels to suit ij with w58 but they are about $350
manmx83
Re: W58 to 1J.can I use an R154 fly.clutch.custom p.p.???????? Tue, 07 June 2005 16:44 Go to previous message
thanks twinturbo86,MR1JZ,Norbie.
Previous Topic:Any Respray Expert here????....
Next Topic:Will a JDM ecu plug straight up to a AUS 4AGE?
Current Time: Sat Oct 31 14:16:47 UTC 2026
Total time taken to generate the page: 0.017707109451294 seconds
