Classifieds » Engines, Accessories and other Mechanicals » (Revised) FS: 1G-GTE Engine & TO4E Turbo Setup
earthweb
Perth, WA.
(Revised) FS: 1G-GTE Engine & TO4E Turbo Setup Fri, 03 June 2005 05:05 Go to next message
Revised after engine and turbo inspection..
______________________________________________ ______________________________________________
Toyota 1G-GTE DOHC 24V Inline 6 Cylinder - $300.00 (Plus $200 for Loom & ECU)
(Suspect blown head gasket, still to confirm)
Generation 2 motor - Lime coloured injectors & yellow ECU plugs.
- Minus Turbos
- Complete Engine Loom with ECU
- Slightly Used Copper Spark Plugs
Plus..
-6 x 440cc Toyota 7M-GTE Injectors - $250.00
-Cut Down Truck Intercooler -SOLD
-GReddy Boost Cut Remover (With Original Box) - $120.00 -SOLD
-Aluminium Catch Can $40.00 -SOLD
-Factory 1G-GTE Intercooler $40.00 -SOLD
-Factory Turbo Heat Shields $10.00
-Factory Twin Turbo Manifold $50.00
-Factory Intercooler Piping and Turbo Piping $50.00
-A Factory 1G-GTE Power Steering Pump (Noisy) - Offers
Single Turbo Setup. Apon taking turbo off I found that water was mixed with the oil inside the oil gallery/shaft of the turbo and inside the wastegate where exhaust gasses go. I've cleaned them both out with spirits and the turbo spins freely now. If you want to buy it then it's your choice but I'm pretty sure it's still okay.
Genuine HKS Cast Iron Single Turbo Manifold $450.00
HKS "COPY" 50mm Wastegate $150.00 ($300 new)
Genuine Garrett TO4E Turbocharger $550.00
Genuine HKS Super Filter air filter element for factory airbox $50.00 -SOLD
Filter has original box aswell.
Pipe from Turbo to Air Flow Meter - Goes with kit as it wouldn't work without it. Although if the kit gets broken up you can offer a price.
I should also point out the w/gate is "fatter" than the w/gate that originally came with the kit. Because of this it fouled on the engine mount, so some "fins" on the w/gate have been shaven back to clear the engine mount. The engine mount was also ground back some aswell. The kit can be bought without the 50mm w/gate so you could buy a 42mm w/gate and this will fit perfectly.
The engine was in my 1988 GZ20 Soarer and has done 104267km's.
Regards,
- Chris.
http://i6.photobucket.com/albums/y216/earthweb/MySingleTurbo.jpg
[Updated on: Thu, 04 August 2005 11:41]
Re: FS: Complete Toyota Single Turbo 1G-GTE Engine Setup $2000 Fri, 03 June 2005 05:53 Go to previous messageGo to next message
Gen2's have yellow injectors.
Pretty sure its Gen3's with Lime.
EvilJack
Sutho/Hills NSW
Re: FS: Complete Toyota Single Turbo 1G-GTE Engine Setup $2000 Fri, 03 June 2005 05:58 Go to previous messageGo to next message
Version 1: Yellow ECU plugs and Yellow injectors. 0.50bar / 7psi.
version 2: Yellow ECU plugs and pale Green injectors. 0.62bar / 9psi
Version 3: Grey ECU plugs and pale Green injectors. 0.75bar / 11psi
Re: FS: Complete Toyota Single Turbo 1G-GTE Engine Setup $2000 Fri, 03 June 2005 06:03 Go to previous messageGo to next message
Franks is a Gen2 with yellow injectors
EMP-2TG
Carlingford, Sydney
Re: FS: Complete Toyota Single Turbo 1G-GTE Engine Setup $2000 Fri, 03 June 2005 06:12 Go to previous messageGo to next message
i got a gen 2 with yellow as well
Snyper
Re: FS: Complete Toyota Single Turbo 1G-GTE Engine Setup $2000 Fri, 03 June 2005 10:55 Go to previous messageGo to next message
looks like a gen3 from the tps
earthweb
Perth, WA.
Re: FS: Complete Toyota Single Turbo 1G-GTE Engine Setup $2000 Fri, 03 June 2005 10:59 Go to previous messageGo to next message
Well, it's from my GZ20 which was built in August 1988 if that helps.
- Chris.
earthweb
Perth, WA.
Re: FS: Complete Toyota Single Turbo 1G-GTE Engine Setup $2000 Mon, 06 June 2005 10:08 Go to previous messageGo to next message
No Message Body
[Updated on: Wed, 22 June 2005 01:42]
earthweb
Perth, WA.
Re: FS: Complete Toyota Single Turbo 1G-GTE Engine Setup $2000 Mon, 06 June 2005 10:10 Go to previous messageGo to next message
Will post pics of engine and stuff when out of car.
- Chris.
earthweb
Perth, WA.
Re: FS: Complete Toyota Single Turbo 1G-GTE Engine Setup $2000ono Tue, 07 June 2005 04:56 Go to previous messageGo to next message
These are some pics of the turbo kit. Pics were taken by the person I bought it off, so the genuine HKS 42mm wastegate pictured isn't included as it's dead. As I mentined it now has a HKS Copy 50mm gate.
http://www.arach.net.au/~earthweb/pics/S2.jpg
http://www.arach.net.au/~earthweb/pics/S3.jpg
http://www.arach.net.au/~earthweb/pics/S4.jpg
- Chris.
[Updated on: Fri, 08 July 2005 04:17]
earthweb
Perth, WA.
Re: FS: Complete Toyota Single Turbo 1G-GTE Engine Setup $2000ono Tue, 07 June 2005 04:58 Go to previous messageGo to next message
Intercooler...
http://www.arach.net.au/~earthweb/pics/S10.jpg
- Chris.
earthweb
Perth, WA.
Re: FS: Complete Toyota Single Turbo 1G-GTE Engine Setup $2000ono Thu, 09 June 2005 01:33 Go to previous messageGo to next message
bump
earthweb
Perth, WA.
Re: FS: Complete Toyota Single Turbo 1G-GTE Engine Setup $2000ono Sun, 12 June 2005 11:56 Go to previous messageGo to next message
bump
[Updated on: Wed, 22 June 2005 01:43]
willwal98
Toowoomba
Re: FS: Complete Toyota Single Turbo 1G-GTE Engine Setup $2000ono Mon, 13 June 2005 03:53 Go to previous messageGo to next message
I would consider buying the single turbo stuff if you did seperate.
chrisma70
no where
Re: FS: Complete Toyota Single Turbo 1G-GTE Engine Setup $2000ono Mon, 13 June 2005 07:19 Go to previous messageGo to next message
im quite interested pending on difficulty puttin this into an ma61 am either after a 7m or this anyone got info on puttin these into to a supra ma61
earthweb
Perth, WA.
Re: FS: Complete Toyota Single Turbo 1G-GTE Engine Setup $2000ono Tue, 14 June 2005 14:30 Go to previous messageGo to next message
chrisma70 wrote on Mon, 13 June 2005 15:19
Are you asking if the turbo setup will fit the 1G in your ma61 or are you asking if this engine will fit into your ma61?
- Chris.
RayJJ
April 2005
Re: FS: Complete Toyota Single Turbo 1G-GTE Engine Setup $2000ono Thu, 16 June 2005 14:00 Go to previous messageGo to next message
hey mate im interested in your engine only and im in perth. is your engine gonna be an easy fix ie. only a new head gasket or is there more damage done?
earthweb
Perth, WA.
Re: FS: Complete Toyota Single Turbo 1G-GTE Engine Setup $2000ono Thu, 16 June 2005 15:08 Go to previous messageGo to next message
Pretty sure it's just the head gasket, but I'll know for sure next week when the engine comes out at my mates house.
I've been pulling it down while it's in the car so I might be able to get the head off before then.
I'm in Inglewood if you wanted to have a preliminary inspection?
- Chris.
RayJJ
April 2005
Re: FS: Complete Toyota Single Turbo 1G-GTE Engine Setup $2000ono Sat, 18 June 2005 03:37 Go to previous messageGo to next message
i have a replacement head & gasket to fit to it if its only that. what price did u want the engine only to go for inc. those 7m injectors? i like the idea of the larger turbo but 2g is a bit more than what i have at the moment. if its floating around in a couple of weeks then ill be interested in the whole pakage.
earthweb
Perth, WA.
Re: FS: Complete Toyota Single Turbo 1G-GTE Engine Setup $2000ono Sat, 18 June 2005 07:00 Go to previous messageGo to next message
Hi Ray,
Well I was looking for $250 for the injectors.
If you just want the engine only, minus the gearbox and loom and ECU then I'll take $300. So $550 all up.
If you want the loom and ECU then add say $200 to that.
- Chris.
RayJJ
April 2005
Re: FS: Complete Toyota Single Turbo 1G-GTE Engine Setup $2000ono Sat, 18 June 2005 09:15 Go to previous messageGo to next message
Will i need the loom for the injector plugs to fit? If there is no other damage, just the blown gasket, then i'm very interested. one other thing, how many km's has it done? my number is 0432276322 so next week when the engine does come out at your mates,sms me the address n ill come have a gander.
- cheers
earthweb
Perth, WA.
Re: FS: Complete Toyota Single Turbo 1G-GTE Engine Setup $2000ono Sat, 18 June 2005 10:31 Go to previous messageGo to next message
Ray, km's are: 104267.
I am using the standard injector plugs, so if you already have a loom for this engine then it'll be fine. The 7M injectors have had 2 pieces of plastic shaved off each one so they fit the standard injector plugs. This doesn't affect them performance or looks wise.
As soon as it comes out and we determine the exact problem I'll SMS you with the details.
- Chris.
[Updated on: Sat, 18 June 2005 10:36]
earthweb
Perth, WA.
Re: FS: Complete Toyota Single Turbo 1G-GTE Engine Setup $2000ono Tue, 21 June 2005 04:43 Go to previous messageGo to next message
The A340E auto box from the 1G-GTE is now not available.
I've been advised it's better than the A342E that came with the 1JZGTE, so it's been switched and is now bolted to the 1JZ.
- Chris.
earthweb
Perth, WA.
Re: FS: Complete Toyota Single Turbo 1G-GTE Engine Setup $2000ono Wed, 29 June 2005 13:18 Go to previous messageGo to next message
$1000 for turbo kit for a short time.
- Chris.
badboybubby
On Probation
Re: (Revised) FS: 1G-GTE Engine & TO4E Turbo Setup Tue, 05 July 2005 23:56 Go to previous messageGo to next message
Pm Sent
VeeP
May 2005
Re: (Revised) FS: 1G-GTE Engine & TO4E Turbo Setup Thu, 07 July 2005 12:02 Go to previous messageGo to next message
Is that truck intercooler and turbo kit still available?
[Updated on: Thu, 07 July 2005 12:04]
earthweb
Perth, WA.
Re: (Revised) FS: 1G-GTE Engine & TO4E Turbo Setup Thu, 07 July 2005 14:30 Go to previous messageGo to next message
VeeP... Yep, but I have someone wanting to buy the wastegate seperate. If he wants it, I can change the price to suit and you could source a new gate from Importbitz for $350.
- Chris.
[Updated on: Thu, 07 July 2005 14:38]
VeeP
May 2005
Re: (Revised) FS: 1G-GTE Engine & TO4E Turbo Setup Sun, 10 July 2005 03:49 Go to previous messageGo to next message
Ok,
would it be possible for me to drop by and have a quick look at the equipment being sold? If so are you able to pm me with details>?
earthweb
Perth, WA.
Re: (Revised) FS: 1G-GTE Engine & TO4E Turbo Setup Mon, 11 July 2005 04:49 Go to previous messageGo to next message
PM'd yesterday.
- Chris.
VeeP
May 2005
Re: (Revised) FS: 1G-GTE Engine & TO4E Turbo Setup Mon, 11 July 2005 10:24 Go to previous messageGo to next message
Cheers Chris, will contact u on Tuesday Smile
brett_celicacoupe
townsville NQLD
Re: (Revised) FS: 1G-GTE Engine & TO4E Turbo Setup Thu, 21 July 2005 08:39 Go to previous messageGo to next message
i recomend this guy to anyone else thinking of buying off him.
the part i bought turned up on time and in good nick.
free bump
earthweb
Perth, WA.
Re: (Revised) FS: 1G-GTE Engine & TO4E Turbo Setup Mon, 25 July 2005 12:32 Go to previous messageGo to next message
Thanks Brett Smile
- Chris.
earthweb
Perth, WA.
Re: (Revised) FS: 1G-GTE Engine & TO4E Turbo Setup Mon, 25 July 2005 12:34 Go to previous messageGo to next message
http://i6.photobucket.com/albums/y216/earthweb/Mani_1.jpg
http://i6.photobucket.com/albums/y216/earthweb/Mani_2.jpg
http://i6.photobucket.com/albums/y216/earthweb/Gate_1.jpg
http://i6.photobucket.com/albums/y216/earthweb/Gate_2.jpg
INTAKE .50 / EXHAUST .63
http://i6.photobucket.com/albums/y216/earthweb/TO4E_Front.jpg
http://i6.photobucket.com/albums/y216/earthweb/TO4E_Rear.jpg
http://i6.photobucket.com/albums/y216/earthweb/TO4E_Side.jpg
http://i6.photobucket.com/albums/y216/earthweb/HKS_Filter.jpg
http://i6.photobucket.com/albums/y216/earthweb/Intake_Pipe.jpg
[Updated on: Mon, 25 July 2005 12:36]
earthweb
Perth, WA.
Re: (Revised) FS: 1G-GTE Engine & TO4E Turbo Setup Mon, 25 July 2005 12:38 Go to previous messageGo to next message
550mm long x 305mm high x 80mm wide
http://i6.photobucket.com/albums/y216/earthweb/Intercooler_Front.jpg
http://i6.photobucket.com/albums/y216/earthweb/Intercooler_Rear.jpg
http://i6.photobucket.com/albums/y216/earthweb/Intercooler_Top.jpg
http://i6.photobucket.com/albums/y216/earthweb/7M_44CC_Injectors.jpg
http://i6.photobucket.com/albums/y216/earthweb/BCR_1.jpg
http://i6.photobucket.com/albums/y216/earthweb/BCR_2.jpg
Aluminium Catch Can
http://i6.photobucket.com/albums/y216/earthweb/Catch_Can.jpg
[Updated on: Fri, 29 July 2005 15:16]
sunset hornet
perth
July 2005
Re: (Revised) FS: 1G-GTE Engine & TO4E Turbo Setup Wed, 27 July 2005 05:57 Go to previous messageGo to next message
so am I correct in saying that you are willing to take 200 for the loom and ecu, coz thats all I need.
i am in perth too if I could come and inspect the ecu.
could you pm the numbers off the top of the ecu.
earthweb
Perth, WA.
Re: (Revised) FS: 1G-GTE Engine & TO4E Turbo Setup Wed, 27 July 2005 12:38 Go to previous messageGo to next message
You are correct Smile
PM sent.
- Chris.
sunset hornet
perth
July 2005
Re: (Revised) FS: 1G-GTE Engine & TO4E Turbo Setup Thu, 28 July 2005 23:51 Go to previous messageGo to next message
so yours is an auto trans ecu yes?
earthweb
Perth, WA.
Re: (Revised) FS: 1G-GTE Engine & TO4E Turbo Setup Fri, 29 July 2005 01:12 Go to previous messageGo to next message
That's correct, it's a factory ecu for the auto 1g-gte.
- Chris.
sunset hornet
perth
July 2005
Re: (Revised) FS: 1G-GTE Engine & TO4E Turbo Setup Fri, 29 July 2005 01:15 Go to previous messageGo to next message
aw poo! Crying or Very Sad Crying or Very Sad need manual! Confused oh well sorry mate that puts me outta the running thanks for your assistance tho?!
earthweb
Perth, WA.
Re: (Revised) FS: 1G-GTE Engine & TO4E Turbo Setup Fri, 29 July 2005 04:06 Go to previous messageGo to next message
Okay, the engine is available for picking bits off now.
It's still complete at the moment, but if you want something just ask and offer me a price, don't forget I'm in Perth so freight would be involved.
I'll provide a pic of what you want but it'll be by camera phone as I don't have a digital camera.
I've also got the whole subframe from the GZ20 Soarer minus the strut towers and springs.
It still has the power steering rack in good condition, as well as the brakes and rotors, sway bar, etc.
I'm looking at cutting the subframe up over the weekend on Sunday if no one wants it, but will retain all the bits that can be unbolted.
Regards,
- Chris.
[Updated on: Fri, 29 July 2005 04:08]
sunset hornet
perth
July 2005
icon10.gif  Re: (Revised) FS: 1G-GTE Engine & TO4E Turbo Setup Fri, 29 July 2005 04:13 Go to previous messageGo to next message
i know i can't buy your computer but I would love to come and have a look at what you have for the 1G, maybe buy the sensors off you? are you willing to sell the sensors seperate to the engine?
if you are, willing to sell sensors can you pm me your address and phone number i'll be round on the weekend.
earthweb
Perth, WA.
Re: (Revised) FS: 1G-GTE Engine & TO4E Turbo Setup Fri, 29 July 2005 15:21 Go to previous messageGo to next message
PM sent.
- Chris.
Airbrushguy
June 2005
Re: (Revised) FS: 1G-GTE Engine & TO4E Turbo Setup Thu, 25 August 2005 11:59 Go to previous message
Can we have a run down of what is still for sale.
I sent you a PM last week about the whole package and got no reply. I would have taken the lot.
I would like to know what is left as what you have has basicly everything I want for my conversion plus more.
Please PM me. I am a genuine buyer.
Previous Topic:FS: FWD 20V-16V extractors. (Holes drilled for both heads) $100.
Next Topic:AE86 Parts, Evo Cooler, Numberplates, CA Conversion gear, Gearbox
Current Time: Thu Oct 22 05:04:03 UTC 2026
Total time taken to generate the page: 0.015974044799805 seconds
