Toymods » The Outhouse » What's doing with your PC
thu187
What's doing with your PC Fri, 03 June 2005 15:54 Go to next message
I recently had a problem with my CTRL+ALT+DEL not working and thought I got some pesky virus crap. Turns out my left ctrl button is stuffed lol.
Anyhow, I stumbled upon TWO REALLY GOOD PROGRAMS.
Firstly, Autoruns. Don't you hate it when you disable programs from loading at startup but they somehow find a way to keep loading? Mad Not anymore my friends.
It's really good. Shows you a list of all the programs set to load @ startup and has a checkbox next to them.
Simply check the ones you want to remain and uncheck the ones you want to stop.
You can also right click and google the names to find out what they do.
Use matches that come from liuitilies.com Smile
Secondly, a really good virus scanner that for some reason can detect a whole lot of shit that other scanners can't.
Known as AntiVirŪ PersonalEdition Classic, it is able to detect partial traces of virus', trojans, worms etc.
The executable is also cleverly named LukeFilewalker Laughing
I recommend you all go and grab them.
Cheers Smile
Autoruns
http://www.sysinternals.com/ntw2k/freeware/autorun s.shtml
http://free-av.com
[Updated on: Fri, 03 June 2005 16:01]
Conquest
Sydney/Wollongong
Re: What's doing with your PC Fri, 03 June 2005 16:35 Go to previous messageGo to next message
You can also use MS Anti-Spyware to disable startup programs.
From memory it's located under advanced tools > system explorer > startup programs. It gives you details of each file such as the file name, location, publisher, version and also what they do in most cases...
[Updated on: Fri, 03 June 2005 16:36]
thu187
Re: What's doing with your PC Fri, 03 June 2005 16:39 Go to previous messageGo to next message
Conquest wrote on Sat, 04 June 2005 02:35
True but it doesn't hook you up with the quick google link AND it failed to detect 7 trojans. To be fair, no other program detected them either but antiVir did Very Happy
h3ff44
melbourne
February 2005
Re: What's doing with your PC Sat, 04 June 2005 02:16 Go to previous messageGo to next message
thanx man ive been lookin for a program like that for a while! some how my comp lets its self get attached to the nasty viruses... i had to format a while ago coz i had some virus that wouldnt allow me to install shit, then i get the ones when you start up pc and get millions of start up programs like ones uve never heard of b4.... like porn pop ups n shit... i dont c y ppl make viruses tiz stupid!!!!!!!
illuminatus
eastern suburbs, melbourne
March 2005
icon10.gif  Re: What's doing with your PC Sat, 04 June 2005 04:40 Go to previous messageGo to next message
have you tried typing 'msconfig' into the run box?
(it only works with winxp)
Bozza
Re: What's doing with your PC Sat, 04 June 2005 04:43 Go to previous messageGo to next message
I've got a problem on my laptop, its alrite for a couple of minutes but then norton antivirus shows a virus and i can't delete it. Doesn't anybody have a program to delete it? I know where the file is and can't delete it aswell. Thanks
thu187
Re: What's doing with your PC Sat, 04 June 2005 05:08 Go to previous messageGo to next message
Bozza wrote on Sat, 04 June 2005 14:43
What's the filename mate?
Soarer
Wollongong
Re: What's doing with your PC Sat, 04 June 2005 05:10 Go to previous messageGo to next message
Turn off System Restore, boot into Safe Mode then run the antivirus again.
Bozza
Re: What's doing with your PC Sat, 04 June 2005 05:23 Go to previous messageGo to next message
I've just found out i got 2 which are similar. Can't remeber both of their names but here is the newest one, wasptis.exe. The other one is something like intranet.exe. Should i go into safe mode and then run antivirus, will this make norton delete the files?
gearb0x
Re: What's doing with your PC Sat, 04 June 2005 08:39 Go to previous messageGo to next message
NOD32
End of story
go home with ur pathetic virus checkers
clubagreenie
1st street on the right
Re: What's doing with your PC Sat, 04 June 2005 13:15 Go to previous messageGo to next message
Whats a virus? Oh that's right, PC users. Laughing
Julz01
Re: What's doing with your PC Sat, 04 June 2005 14:08 Go to previous messageGo to next message
To get rid of all you start up programs type in msconfig in the run and this will give you a menu that has the start up programs in it, you are able to select the exe you want to start up at the start of windows and you can de select them as well.
Kodoku
January 2005
Re: What's doing with your PC Wed, 08 June 2005 13:36 Go to previous messageGo to next message
Now if only there was a program that would solve my bsod problems... Rolling Eyes
ta23
Re: What's doing with your PC Wed, 08 June 2005 13:48 Go to previous messageGo to next message
Have you tried the symantec site for removal tools, most viruses that nortons cant remove they will have a removal tool for.
ta23
Re: What's doing with your PC Wed, 08 June 2005 13:52 Go to previous messageGo to next message
Kodoku wrote on Wed, 08 June 2005 23:36
BSOD possibly hardware aswell. It depends what BSOD messgae you are getting. Run a format/reinstall on you machine for starters, if that doesnt help, look at hardware devices, take out PCI cards and try new ram.
Hope that helps
acreese
Re: What's doing with your PC Wed, 08 June 2005 15:30 Go to previous messageGo to next message
Bozza wrote on Sat, 04 June 2005 13:23
Bozza,
what soarer suggested should work in most cases, but if not.
Option 1:
press ctrl + shift + escape. Under the "processes" tab search for the filename. Select end task.
Seach for the file using windows search.
Select it, and hit delete. [Works for exe files]
Or
Run nortons, a write down file names.
Use windows search and write down file path to the files.
Reboot computer in MS DOS mode (can use a boot disk for this)
Navigate to each file to Delete using dos commands.
You can even get clever and write a batch file in windows to do this for you. Call it from in the autoexe.bat or config.sys files, then reboot PC.
Lastly, that MSCONFIG.sys is very handy. Read up on it, it can get you out of a jam or too Smile
-Adam
inertia
Re: What's doing with your PC Wed, 08 June 2005 16:36 Go to previous messageGo to next message
msconfig is win98 aswell.
Also, HiJackThis, Pest Patrol, Spybot S&D, AdawareSE, Webroot SpySweeper... usually u need to work it out and remove the remenants of the fuckers manually...
this is my day job and I hate cleaning machines, it's just so frickin annoying these days that even after finally cleaning a machine up after an hour or 4 and you beat the lil motherfuckers, you then have to repair alot of the damage done... and then the customer says "you're charging me what!!!" Mad I suppose if you want it done for $5 I can just delete the partition(s) and give it back to you... Rolling Eyes
Cleaning up failed attempts to fix problems is interesting also... mainly cause ppl have installed everything with the name anti spyware, adware etc and these things are actually nasty pests themselves! Laughing
Re: What's doing with your PC Thu, 09 June 2005 00:19 Go to previous messageGo to next message
jeez guys ... ever thought of migrating to linux?
then the wasted days of chasing down and killing spyware/malware/adware will be behind you.
Caledwvech
Re: What's doing with your PC Thu, 09 June 2005 00:53 Go to previous messageGo to next message
Dude, sell your PC and buy a Mac. All your virus days will be over. All your error and CTRL-SHIFT-DEL days will be over. Very Happy
river
Land of Oz
Re: What's doing with your PC Thu, 09 June 2005 01:38 Go to previous messageGo to next message
I just spent the morning running Autorun, then upgraded the new Adaware and ran it and then I did SpyBot Search & Destroy and then I ran Registry Mechanic. All lovely and clean now.
Yeah, thought about getting a Mac, but personally I regard them as the FWD automatic Honda of the PC world. So, I'll stay with my PC for the time being, though it is getting a little long in the tooth and I should upgrade to something faster, more memory and with better graphics. But there's work to be done on the car... and the house (the true blackhole for money).
seeyuzz
river
inertia
Re: What's doing with your PC Thu, 09 June 2005 01:41 Go to previous message
I personally have a dual boot linux install on this machine and another linux box.
I only have windows xp on here for gaming, however sometimes find I can't be fucked rebooting to browse the net Crying or Very Sad However, firefox does help keep the nasties away, and I don't go looking up crapola on the winxp install... linux helps for that.
Another option is to have an image file of you computer once you set it up the way u like and have your downloads etc on a different drive or backed up...
Previous Topic:nice audi ad (picture not video)
Next Topic:Cristie from Big Brother
Current Time: Thu Oct 22 06:55:00 UTC 2026
Total time taken to generate the page: 0.0076141357421875 seconds
