Toymods » Tech & Conversions » gear down shift problems HELP!!!!!!!!
sleeker162
gear down shift problems HELP!!!!!!!! Sat, 04 June 2005 04:42 Go to next message
hey, need help asap,
my celica (st162 with 3sgte conversion) wont down shift through the gears.
it up shifts fine, nice n smooth, but wont change back down, untill the car is stationary. everything looks to be correct, clutch has good feel / pressure,
i can select all gears when car is running and stationary, same as i can select all gears when car is switched off, both the gear selection cables are moving correctly, slave cylinder is moving fine. everything looks n feels fine cept i cant downshift.
gear box doesnt crunch on up shift, very smooth.
someone help!!!!!!!!!!!!!!!!
pm me back or call me 0438 187 797
cheers jesse
HyDrA
Adelaide, SA
Re: gear down shift problems HELP!!!!!!!! Sat, 04 June 2005 05:00 Go to previous messageGo to next message
Can you revmatch on downshift? Does this help the gears engage?
kwayzivietnamese
Re: gear down shift problems HELP!!!!!!!! Sat, 04 June 2005 06:19 Go to previous messageGo to next message
HyDrA wrote on Sat, 04 June 2005 15:00
Yeah, wot he/she said. Try and heel toe it or just rev it then shift down...if it doesnt gear down doing this, then u got problems Confused
sleeker162
Re: gear down shift problems HELP!!!!!!!! Sat, 04 June 2005 08:11 Go to previous messageGo to next message
hey i tryed rev matchin, didnt do much, the only progress i made is that i can now down shift from 4 - 3rd with a double clutch, but still cant pull 2nd.
someone suggested that maybe my clutch setup is just slowly workin itself into place, as the setup has only done no more that 2km.
idea's? i mean that sounded like a reasonable idea considering that i couldnt down shift at all earlier today.
some feed back guys.
also, lol i had a "toyota specialist" mobile mechanic come out to have a look, all he could come up with is "fucks me" he didnt even charge me lol
Celica_John
Re: gear down shift problems HELP!!!!!!!! Sat, 04 June 2005 09:50 Go to previous messageGo to next message
what gearbox are you using more importantly?
if the clutch is only 2kms old that means you had the box out 2kms ago! don't say you put the stocka box back in!
those gearboxes have problems with the synchros on a n/a motor.
sleeker162
Re: gear down shift problems HELP!!!!!!!! Sat, 04 June 2005 09:59 Go to previous messageGo to next message
its the stock s53 box but it is in pristeen condition, when i drained the oil it was crystal clear, it up shifts beautifully,
CLG suggested that it may be a stretched selector cable, anyone know how to confirm this?
also when tryin to down shift it doesnt grind it just hits on the gate, cant go past it.
towe_001
Somewhere on a dirt bowl ...
Re: gear down shift problems HELP!!!!!!!! Sat, 04 June 2005 10:38 Go to previous messageGo to next message
Have you made sure that all the bolts are done up tight ?
Could even be something loose on the inside - flywheel, pressure plate. But with you being able to upgear i couldn't see that being something. But still......
I kind of think CLG is most likely on the money with a stretched cable, more then likely it'd be the cable for the up/down movement.
Just a left of field odd ball idea but you sure you got the cables around the right way ? But like i said "odd ball"
sleeker162
Re: gear down shift problems HELP!!!!!!!! Sat, 04 June 2005 10:53 Go to previous messageGo to next message
towe_001 wrote on Sat, 04 June 2005 20:38
...... i was certain untill you said that.
ill have to get someone to take a pic of there's to compare it to mine now, damn you putting doubt in my mind.
sleeker162
Re: gear down shift problems HELP!!!!!!!! Sun, 05 June 2005 07:04 Go to previous messageGo to next message
looks fine.
when drivin in second, as soon as i take my foot off the gas it pops outta gear.
StuC
Re: gear down shift problems HELP!!!!!!!! Sun, 05 June 2005 12:18 Go to previous messageGo to next message
Its your detents and interlocks then mate. The detents hold are basically runners with spring loaded ball bearings which lock into a little groove ont he shaft and hold it in gear.These get worn and as you can see it pops out.If one is stuck it can also stop it from changing altoghether.
Along with these there are interlocks which are there so that you may only select one gear at a time.THese two can be worn and will result in major gear clashing, crunching and if you do manage to get it into gear the car will stall and lock up the box and cause uber skiddies on bolthj the road and in your pants.
Id be taking the box out and getting it looked over by an expert.
I pulled apart a pulsar box the other day which probably had the same problems with its mechansims and found that a spring had just lost its temper and the detent balls were just not moving around enough.
Hope this helps mate and good luck
sleeker162
Re: gear down shift problems HELP!!!!!!!! Sun, 05 June 2005 12:41 Go to previous messageGo to next message
thanks guys, just gonna put it in a shop and throw money at it to make to problem go away
StuC
Re: gear down shift problems HELP!!!!!!!! Mon, 06 June 2005 11:01 Go to previous message
There is an MR2 LSD for sale down here with 65,000kms on it - they're wanting 1k - you should buy that Jess, you know you want to
Previous Topic:turbo drain facing up
Next Topic:Unleaded petrol in a 4K-C Corolla???
Current Time: Thu Oct 22 18:55:32 UTC 2026
Total time taken to generate the page: 0.0057969093322754 seconds
