Toymods » Tech & Conversions » Any Respray Expert here????....
ae86driftstyle
Any Respray Expert here????.... Sat, 04 June 2005 12:51 Go to next message
Want to know what's different between..
Arcylic, 2 pack, air dry enamel..
which one has a better finish and last longer (without Baking)
Thanks.....
Or anyone know someone or some place do some cheap
respray job..
Thanks for the reply^^
styler
Re: Any Respray Expert here????.... Sat, 04 June 2005 13:33 Go to previous messageGo to next message
acrylic - common enthusiast paintjob, water based, not as glossy as 2 pack, dries slower, not as hard, easy to fix small sections when spraying.
enamel - not recommended at all
2 pack - common pro paintjob, very good gloss, hardens fast and well, need to have protective equipment, hard to fix small sections when spraying.
better finish with 2 pack but same finish can be achieved with acrylic.
yes there are lots of places that do a cheap respray. spraying is easy and about 10% of the paintjob. perparation is about 90%
[Updated on: Sat, 04 June 2005 13:34]
takai
Re: Any Respray Expert here????.... Sat, 04 June 2005 13:44 Go to previous messageGo to next message
Acrylic with a 2Pac top coat gives almost as good a result as complete 2Pac. But with a smaller price tag.
kwayzivietnamese
Re: Any Respray Expert here????.... Sat, 04 June 2005 23:44 Go to previous messageGo to next message
2pac is the way to go.
Uve been pmed for the connection Wink
Meat_rack
East Maitland NSW
Re: Any Respray Expert here????.... Sun, 05 June 2005 00:47 Go to previous messageGo to next message
What is wrong with enamel?
ChuckLandwehr
Re: Any Respray Expert here????.... Sun, 05 June 2005 02:56 Go to previous messageGo to next message
Non bake enamel, skins over, and dries very very slowly.
Baked enamel process involves heating the car first, which causes the paint to dry from the bottom out, no skin.
Most factory finishes up to the late 1980's were baked enamel.
Touch up was generally with acrylic.
Whole panel repairs were baked at panel shops.
cheers Chuck.
rokusan
western queensland
Re: Any Respray Expert here????.... Sun, 05 June 2005 04:34 Go to previous messageGo to next message
takai wrote on Sat, 04 June 2005 23:44
unfortunatly the rate of expansion and contraction between acrylic laquer base coat and a 2K clear is differant and therefore will separate over time giving the flaking off of the clear like old commodores etc. ie: dosen't work
the methods of blending and touch ups for acrylic laquer and 2k are the same, 2K if anything is less temperamental so easier for the amatuer. Solid coulors use a different method thats even easier again such as white or red.
enamel doesen't have the UV protection like 2k so will fade, touch ups are also tricky though i do it every day.
ae86driftstyle
Re: Any Respray Expert here????.... Sun, 05 June 2005 07:04 Go to previous messageGo to next message
But I have heard from some
Panel Beater say if I want to
do a 2 Pack Respray Job...I must Bake it..
True???
haha...1 more question...
with out a Baking...
which is the best finish (Arcylic, 2 pack)
Which last linger (Arcylic, 2 pack)
Thanks for all prefessional Advice guys!!!
Simon-AE86
Banned user
ADELAIDE - The Drift City
Re: Any Respray Expert here????.... Sun, 05 June 2005 09:00 Go to previous messageGo to next message
all newer holdens are painted with acrylic base and 2 pac clear on top. and this is what i have done with my new car (asince its a holden colour and all.)
its a lot easier then straight 2 pac thats for sure...
ChuckLandwehr
Re: Any Respray Expert here????.... Sun, 05 June 2005 10:53 Go to previous messageGo to next message
PPG paint resellers can supply "COBRA" paints.
Effectively it is an acrylic, with a 2Pak clearcoat.
The acrylic, and 2Pak are formulated to expand and contract at the same rate, which will reduce/eliminate the cracking mentioned in this thread.
cheers chuck.
Gwaijaitat
April 2005
Re: Any Respray Expert here????.... Tue, 07 June 2005 12:14 Go to previous messageGo to next message
kwayzivietnamese wrote on Sun, 05 June 2005 09:44
would you mind to connect me too Embarassed I need a respray too;)
RWDboy
Re: Any Respray Expert here????.... Tue, 07 June 2005 12:58 Go to previous messageGo to next message
Acrylic is the go for me, as I can't afford the protective equipment to do 2 pak - whereas what is required to spray acrylic is far less expensive.
Having said that, it takes a lot more work to make acrylic look as good as 2 pak.
ae86trueno
Re: Any Respray Expert here????.... Tue, 07 June 2005 22:32 Go to previous message
If your going to paint in Acrylic go get some Protec Acrylic,
I tried a few manufactures when i painted the rally car, and they were by far the best, high gloss finish off the gun and virtually no sanding or polishing to get a good shine.
Ben.
Previous Topic:UZZ30/JZZ30 Soarer Fuse Box Lid Picture
Next Topic:W58 to 1J.can I use an R154 fly.clutch.custom p.p.????????
Current Time: Mon Nov 2 00:15:21 UTC 2026
Total time taken to generate the page: 0.010994911193848 seconds
