Toymods » Tech & Conversions » 1jz smoke problem
tyottsoarer
Gold Coast
1jz smoke problem Sat, 04 June 2005 15:48 Go to next message
Hi.
I have been told my car is blowing white smoke under heavy acceleration. I have also noticed that after a drive if you were to start the car up again maybe 5 mins later it would puff out a nice cloud of white smoke for maybe 15 seconds then nothing. It doesn't seem to be blowing smoke under free reving. Would this be valve stem seals or turbo seals or..... piston rings.
If it is valve stem seals what is involved in replacing them labor wise to me or cost wise to a mechanic.
Skip
Re: 1jz smoke problem Sun, 05 June 2005 09:13 Go to previous messageGo to next message
Valve stem seals will not blow smoke under hard acceleration cause the boost pressure in the cylinder stops this. If they are screwed smoke will only blow under situations of high vacuum i.e. when the throttle plate is closed after hard acceleration (high rpm), and hard braking.
Definitely sounds like turbo seal.
tyottsoarer
Gold Coast
Re: 1jz smoke problem Sun, 05 June 2005 12:21 Go to previous message
Yep, I was thinking this but just needed confirmation.
Previous Topic:Low Dwell Question
Next Topic:7mge sump?
Current Time: Fri Nov 20 19:43:08 UTC 2026
Total time taken to generate the page: 0.014562845230103 seconds
