Toymods » Tech & Conversions » Low Dwell Question
ae86trueno
Low Dwell Question Sun, 05 June 2005 07:13 Go to next message
What would cause a low Dwell value at low RPM then return to normal at higher RPM ??
I am using a Standard 4AGE 100 KW distributor and a bosch coil and igniter.
It has me a little stumped ???
Ben.
Fattony
Re: Low Dwell Question Sun, 05 June 2005 08:13 Go to previous messageGo to next message
Im not 100% certian about this but does your car use a ballast resistor, and if so could it be that that is worn.
allencr
tallahassee FL usOFa
Re: Low Dwell Question Sun, 05 June 2005 12:26 Go to previous message
how much does the shaft wobble??
also the mickey mouse plate that the vacuum advance moves, if its got one.
worn bearings and/or shaft.
Previous Topic:2A-GE, anyone done it?
Next Topic:1jz smoke problem
Current Time: Fri Nov 20 20:34:13 UTC 2026
Total time taken to generate the page: 0.0048718452453613 seconds
