Toymods » Tech & Conversions » T-50 to 3TGTE
ToyT18
Hobart
T-50 to 3TGTE Sun, 05 June 2005 07:37 Go to next message
hi,
when putting the engine in can i use the 3TGTE flywheel and clutch that came with the engine? or do i have to use the 3TC flywheel but i want to use the clutch disc and presure plate
TA22 GT
Re: T-50 to 3TGTE Sun, 05 June 2005 07:46 Go to previous messageGo to next message
No you have to use the 2T/3T stock flywheel and clutch. The 3T GTE unit is to big for the T50 gearbox.
The best you can do is a slightly bigger clutch from the T18 over the stock 2T clutch.
Cya,
Simon
ToyT18
Hobart
Re: T-50 to 3TGTE Sun, 05 June 2005 07:54 Go to previous messageGo to next message
can i use the clutch disc that came with my 3TGTE which is brand new with the stock 3TC pressure plate onto the stock 2T 3T flywheel?
ToyT18
Hobart
Re: T-50 to 3TGTE Sun, 05 June 2005 07:55 Go to previous messageGo to next message
also usuing the 2T/3T flywheel does this mean i need to use the T-18 starter motor or can i still use the 3TGTE?
TE72_Turbo
Re: T-50 to 3TGTE Sun, 05 June 2005 07:58 Go to previous messageGo to next message
Why don't you try lining them up? You'll soon work out that it doesn't work Razz
The main issue here is that the proper 3TGTE clutch has 29mm x 21 spines for a W5* box, unlike the smaller 23.8mm input shaft of the T50, so in short, NO, you cannot use the clutch plate with your T50 gearbox at all.
You can however use the larger 3TGTE flywheel & pressure plate, and purchase a new clutch plate (not expensive) to suit the 225mm diameter, and 23.8mm x 21 spline T50 box. I did this with mine. The larger flywheel fits fine in the T50 bellhousing, and the ring gear is exactly the same, so no issues with the starter motor.
Phil
TA22 GT
Re: T-50 to 3TGTE Sun, 05 June 2005 11:15 Go to previous messageGo to next message
Yep, either flywheel is fine as is either starter motor.
But you just cant use the 3T GTE clutch with the T50 as mentioned already.
Simon
bunkyT18
Pilbara
Re: T-50 to 3TGTE Sun, 05 June 2005 11:22 Go to previous messageGo to next message
I just scored a manual Crown clutch for exactly this application. Cost me $60. I'm getting it tuesday so i'll let u all know how I go.
[Updated on: Sun, 05 June 2005 11:25]
ToyT18
Hobart
Re: T-50 to 3TGTE Sun, 05 June 2005 13:45 Go to previous messageGo to next message
ok so i can use the 3TGTE pressure plate and the flywheel just need a new disc to fit the splines.
ToyT18
Hobart
Re: T-50 to 3TGTE Sun, 05 June 2005 13:46 Go to previous messageGo to next message
yeah i havent got the motor or anything out yet so i cant compare i just need to get it all ready to convert so i can do everything in one hit and have the car off the road for only a short amount of time. thanks for the info fellas
Re: T-50 to 3TGTE Mon, 06 June 2005 00:22 Go to previous messageGo to next message
I'm surprised no-one has mentioned this yet, but your T50 isn't likely to last very long behind a turbo engine. Maybe you'd be better off doing a W5x conversion straight away?
ChuckLandwehr
Re: T-50 to 3TGTE Mon, 06 June 2005 02:10 Go to previous messageGo to next message
Norbie, you have hit the nail on the head, I could not agree more. The 3TGT, came in factory form with a W55 box. Obviously, the factory thought that a T50 would not cope!!!!
How many guys with RWD conversion 4AGTE's are still using the T50? Not too many, I would think.
Even Atmo 4AGE, and 3T/2T hybrids have been known to shred T50's
W55's are commonly available from 2SC powered SA6x Celica's.
Bellhousing may be a little harder to find, but come up 4 sale on these forums.
A 1G-GTE bellhousing would also suffice, if you can live with the clutch slave cylinder on the LH side. Or convert to the RH side.
cheers Chuck.
ToyT18
Hobart
Re: T-50 to 3TGTE Mon, 06 June 2005 07:49 Go to previous messageGo to next message
oh well when it breaks i will replace it, just reading the new drift battle and both 4AGTE sprinters are using T-50s with over 150rwkw so my engine will only have about 90-100rwkw so it should last for a while seeing as im not going to be thrashing the guts out of it.
bunkyT18
Pilbara
Re: T-50 to 3TGTE Tue, 07 June 2005 04:03 Go to previous messageGo to next message
The T50 should be able to cope with 180 to 200bhp at the flywheel. My conversion knowledge (no doubt someone will have other ideas)says that there will be conservative estimate of 30% drivetrain power loss so;
200 x 30% = 60
140 hpatw converted to kwatw = 104.4kwatw
It's not so simple either to just drop a W55 or other W series Gbox in. You will need to find a cressida 1 piece driveshaft and shorten it by about an inch and also stuff around with gbox mounts.
If you so want to make more horsies later then it's definitely no other option than to go the W series gbox though.
Re: T-50 to 3TGTE Tue, 07 June 2005 04:44 Go to previous messageGo to next message
ToyT18 wrote on Mon, 06 June 2005 17:49
Famous last words? Wink
Yian
Lwr Templestowe, Melbourne
Re: T-50 to 3TGTE Tue, 07 June 2005 04:50 Go to previous messageGo to next message
Norbie wrote on Tue, 07 June 2005 14:44
I'd say so heh Razz
ToyT18 wrote on Fri, 27 May 2005 22:20
I personally wont be doing any real racing on the roads till the new engine is in and i have a race seat and harnesses
So much for not trashing it Laughing
ToyT18
Hobart
Re: T-50 to 3TGTE Tue, 07 June 2005 08:00 Go to previous messageGo to next message
u have no faith in toyota boxes? its been rebuilt 6 months ago. You guys dont need to stress yourselves about wether my gearbox will hold up or not i spose thats my problem. Very Happy Are you stalking me Yian?
ToyT18
Hobart
Re: T-50 to 3TGTE Tue, 07 June 2005 08:11 Go to previous messageGo to next message
has anyone here actually used a "Good" T-50 behind a 3TGTE?i was driving my mates capella with a 200rwkw and that had an old rX4 4 speed in bad condition thats held up to track days and drag racing.
GOT_M.I.L.F.
adelaide
Re: T-50 to 3TGTE Tue, 07 June 2005 08:29 Go to previous messageGo to next message
ive still got my t50 behind 3tgt and its held up to a caining
*touch wood*
Re: T-50 to 3TGTE Tue, 07 June 2005 12:39 Go to previous messageGo to next message
ToyT18 wrote on Tue, 07 June 2005 18:00
You need more than faith to make a gearbox hold together. A T50 was never designed to see much more than 100hp.
bunkyT18
Pilbara
Re: T-50 to 3TGTE Wed, 08 June 2005 03:20 Go to previous messageGo to next message
But the T50 will hold much more than that. I mean, a 3TGTEU was designed to drop about 115.5hp at the treads but everybody is happy enough to make them do double that if they can. If the T50 was designed to cope with only 100hp then what are all those 100kw+ 4AGE'S doing with them? It's not really a debate. This bloke is doing a similar thing to me in that he is running a lightly tuned motor that will not be putting out much more than stock power. The T50 should cope with that. Later on, once the hungerbug for more power comes (which it will, hehehe), he can do whatever he likes. At the end of the day, if he wants to bust his T50 and blow up his motor he can cos the car is his... (Not that thats gonna happen, hey?)
blackRA28
adelaide
Re: T-50 to 3TGTE Wed, 08 June 2005 03:33 Go to previous messageGo to next message
IL be running a t-50 behind my 3T-gt for as long as it lasts.. and while im saving up $300 odd bucks for a bellhousing, and $400-500 odd bucks for a w55/7/8.
What flywheel/pressure plate/clutch plate/tailshaft configuration does one need for running a W55 or W58 series box with a 3Tgt, in a TA23 chassis? (standard t292 rear end)
I bet i could find the answer if i searched... Laughing
bunkyT18
Pilbara
Re: T-50 to 3TGTE Wed, 08 June 2005 05:46 Go to previous messageGo to next message
I dunno what configuration it is but I got it in my shed (not for sale) lol.
Can find out specs if you are really interested...
Is this a Hybrid 3TG? Or is it the turbo twin cam 3TGTEU you are talking about (above quote)?
Re: T-50 to 3TGTE Wed, 08 June 2005 05:50 Go to previous messageGo to next message
bunkyT18 wrote on Wed, 08 June 2005 13:20
Of course he can do what he bloody likes, but what's the problem with people trying to give some useful advice FFS? Rolling Eyes
Sometimes I wonder why I bother with this place...
bunkyT18
Pilbara
Re: T-50 to 3TGTE Wed, 08 June 2005 06:31 Go to previous messageGo to next message
Hey Norbie, nothing's wrong with giving advice ... I don't think anyone disagreed with you man...
There there lol
ToyT18
Hobart
Re: T-50 to 3TGTE Wed, 08 June 2005 11:04 Go to previous messageGo to next message
Sorry norbie about the confusion i didnt mean to sound rude or anything. I wasnt saying your wrong, i know the T-50's arent meant to hold up the the power but its been done plenty of times b4 i just personally think that it will hold up for the time i need it for and its hard to not get pissed off when someone says it wont be up to it when ive seen cars like 4AGZE sprinters with T-50's no one questions them and they have a very similar power output!
bunkyT18
Pilbara
Re: T-50 to 3TGTE Mon, 27 June 2005 02:58 Go to previous messageGo to next message
Just a FYI on the manual Crown clutch plate for the 3TGTE W58 pressure plate/flywheel combo to the T50. It's a goer! Fit's nicely and matches up to the T50 spline no worries. It's little bit smaller than the stock clutch plate on the inside pressure plate measurement diameter but it all fits no worries.
September_Squall
Melbourne, Australia
March 2005
Re: T-50 to 3TGTE Tue, 28 June 2005 01:26 Go to previous messageGo to next message
What model crown? What diameter friction plate?
bunkyT18
Pilbara
Re: T-50 to 3TGTE Tue, 28 June 2005 05:03 Go to previous message
See the specs above. I just asked PBR to look for a clutch from a manual crown. Manual crowns are JDM, most ADM Crowns were auto's.
Previous Topic:Haltec vs others computers
Next Topic:2tgeu weight?
Current Time: Tue Oct 27 09:15:55 UTC 2026
Total time taken to generate the page: 0.076204061508179 seconds
