Toymods » Tech & Conversions » AE92 Stalling
djcougar
Sydney, Australia
AE92 Stalling Sun, 05 June 2005 13:32 Go to next message
Howdy
my missus 1990 Corolla Seca CSi stalls her on randomly, its an auto and recently had a full service and was told it was in perfect working order, she bought it no long ago and been stalling since the day she bought it.
anybody have any idea's on what could cause it to just randomly stall??
thanking you in advance
dimmy77_03
Potts Point, Sydney
Re: AE92 Stalling Mon, 06 June 2005 00:08 Go to previous messageGo to next message
i had this happen to me on friday night, just stalled at a set of lights (luckily no-one around), then started up again fine. The next day i was coming out of a shopping centre, just got over the hill and stalled again.
Figured it was because 1st cylinder ignition lead was fucked so the car was running erraticaly...
Change the leads, they're only about $30
sxr01r
The Hills District
Re: AE92 Stalling Mon, 06 June 2005 08:10 Go to previous messageGo to next message
im assuming that the car is injected so ill work from there. heres a few things it could be.
-leak in the induction pipe, ie anywhere between the throttle body and airbox.
-clogged or damaged etc vacuum hoses. ie the ones that run from the throttle body to the airbox or whatever.
-timing? - if the car runs fine then i doubt it will be this and especially if the mechanic said its fine.
-could be leads as prev mentioned
-clogged air filter element
if the vacuum hoses are damaged in any way or the induction pipe has a hole in it or is leaking even at the clamps then the sensors in the pipe or airbox will not be getting correct readings on air temp and flow etc hence the computer getting wrong readings and not idling properly. if the vacuum hoses are damaged then the engine wont be getting enough air at idle hence its stalling
if all that turns out alright then maybe its just the idle screw
hope that helps. leigh
thu187
Re: AE92 Stalling Mon, 06 June 2005 08:44 Go to previous message
Mine stalled when the steering was at full lock Confused You'd notice it bubbling and the revs dropping so you just tapped the gas and everything was alright Smile
Previous Topic:1GGZE S/C question
Next Topic:4A-GZE pistons, the TRUTH!
Current Time: Tue Oct 20 08:51:53 UTC 2026
Total time taken to generate the page: 0.0055859088897705 seconds
