Toymods » Tech & Conversions » Stubborn Inner tie rod ends
hickoz_bro
Stubborn Inner tie rod ends Mon, 06 June 2005 05:17 Go to next message
hey all... gotta change the inner tie rod ends on my ra28, but the sons of bitches won't move...
i've managed to get the outer tie rod ends done and loosened the idler arm, so i have one of two options... i can remove the pitman arm, or the right inner tie rod end... but it ain't budging... any suggestions? i've got all the nuts loose, just can't crack the tapers...
Cyber-punk
Brisbane, QLD
Re: Stubborn Inner tie rod ends Mon, 06 June 2005 06:05 Go to previous messageGo to next message
Try soaking it in WD40\inox something like that
Or you could try some shock treatment(smack it with a hammer a few times around the taper...firmly but not too HARD)
hickoz_bro
Re: Stubborn Inner tie rod ends Mon, 06 June 2005 06:22 Go to previous messageGo to next message
RP7 and ROST OFF was all i could get my hands on... and persuasion techinique did jack... still tight as...
wilbo666
Re: Stubborn Inner tie rod ends Mon, 06 June 2005 06:32 Go to previous messageGo to next message
There are a few options...
-get a tie rod puller for $20 or so from a cheap tool place (supercheap etc)
-get two hammers and hit the sides of the steering arms opposite each other at the same time (jars the taper loose). Then thread on the nut so that you will not damage the top of the tie rod end (if you are reusing it) and also to give a larger surface area to hit...I find placing a chock under the arm to stop it moving/locate it and then bashing the crap out of the nut works quite well Smile If it still wont come, hit the sides some more, then try again...repeat as needed... Smile
[Updated on: Mon, 06 June 2005 06:35]
ra_28
Re: Stubborn Inner tie rod ends Mon, 06 June 2005 06:33 Go to previous messageGo to next message
A good trick and usually works get two hammers and hit both sides of the boss at the same time this does loosen the taper.
hickoz_bro
Re: Stubborn Inner tie rod ends Mon, 06 June 2005 22:44 Go to previous message
yeah... tried that too... gonna jack the car up higher today, see if i can belt it into submission... stubborn prick Mad
Previous Topic:18-RG -> RT104 ***update***
Next Topic:ra23 conversion
Current Time: Wed Oct 14 12:04:50 UTC 2026
Total time taken to generate the page: 0.04767894744873 seconds
