Toymods » General Car Talk » How much power do you think I will make?
Fabbz
How much power do you think I will make? Mon, 06 June 2005 07:59 Go to next message
Hey all.
My 1JZ swap is almost complete! Shocked It should be dynoed this week on a dynomometer NOT a dyno dynamics.
What power do you think I will make with my following mods??? Keeping in mind Im well awawre that dyno results are just a number and NOTHING to brag about and that each car will produce a different result. What are most people making with similar mods?
80 000Km's 1JZGTE
R154
New heavy duty organic clutch
2.5inch into 3inch dump pipes
3inch turbo back exhaust + 3 inch downpipe + 3inch High flow cat
K&N pod intake
Apexi SAFCII
Turbosmart Eboost
HKS SSQ BOV
15psi
I will be using the stock intercooler and pipes until my next paycheck....Im saving for an HKS Type S intercooler kit. Very Happy
Alex Smile
[Updated on: Mon, 06 June 2005 08:31]
4agte
Toronto, Downtown
Re: How much power do you think I will make? Mon, 06 June 2005 08:02 Go to previous messageGo to next message
i wouldnt go running 15psi on the stock i/c but i would expect with a sizeable front mount and the mods you have quoted that 200-220rwkw would not be unexpected on a dyno dynamix dyno. A friend of mine make 226kw atw on a dyno dynamics and its an auto with similar mods and 14psi
Fabbz
Re: How much power do you think I will make? Mon, 06 June 2005 08:22 Go to previous messageGo to next message
Thanks for the input 4agte, appreciate it. Why wouldnt you run 15psi on stock cooler? I didint know the cooler was such a limiting factor and actually read that the JZA70 cooler flows fairly well, etc. How much boost would you reccommend I run? I guess a few dyno pulls will be done and we will find the best medium of Inlet Temps and power.
[Updated on: Mon, 06 June 2005 08:23]
4agte
Toronto, Downtown
Re: How much power do you think I will make? Mon, 06 June 2005 08:29 Go to previous messageGo to next message
its not the flow its heatsoak im not too sure about jza70 intercoolers but with most oem i/c's they are only really efficient at disapating heat at stock boost pressures.
Furthermore from memory 1jzgte's stock turbines wheels are ceramic and therefore running them at anything higher than 14psi is asking for a turbine wheel stuck in the cat. This may not allways the case as i have heard of people making them last at 18psi.
Have you had custom dump pipes made for the turbos as the factory one is supposed to be quite restrictive from what i hear there are good gains to be made my friends one runs custom dump pipes and makes good power for an auto
Fabbz
Re: How much power do you think I will make? Mon, 06 June 2005 08:34 Go to previous messageGo to next message
Yeah I got some custom made dump pipes from these forums, so yeah they are mentioned in my mods list above. I guess Im a little worried about running 15psi, as I knew about the ceramic wheel problem, but I havn't actually heard of anyone blowing them out so to speak, and if I can keep everything cool then the turbos should be fine....BUT.....I guess Im playing with fire so I might turn the boost down a little Rolling Eyes However its only a matter of time before I get some KKK K26 Blitz turbos in there Very Happy
4agte
Toronto, Downtown
Re: How much power do you think I will make? Mon, 06 June 2005 08:40 Go to previous messageGo to next message
well if your upgrading the turbos anyway then y not but it would suck to have to drive arround with no boost and these things tend to go wrong when you need it the least 14psi would be nothing to sneeze at
KOFFEE-BLACK
Re: How much power do you think I will make? Mon, 06 June 2005 10:02 Go to previous messageGo to next message
I make 210rwkw with 13psi, 3" exhaust, FMIC.
Ribfeast
Newcastle, Australia
March 2005
Re: How much power do you think I will make? Tue, 07 June 2005 03:07 Go to previous messageGo to next message
Any other mods Koffee? Which FMIC are you running? And what are you using to set the boost to 13PSI?
KOFFEE-BLACK
Re: How much power do you think I will make? Tue, 07 June 2005 07:09 Go to previous messageGo to next message
Im using a Hybrid cooler, and custom 3" exhaust from the dumps back and hi flow cat. Im using the E-Boost.
Re: How much power do you think I will make? Tue, 07 June 2005 07:12 Go to previous messageGo to next message
Sorry for the hijack, KOFFEE, was that your car in the magazine?
Classique71
Colac, Victoria
Re: How much power do you think I will make? Tue, 07 June 2005 08:28 Go to previous messageGo to next message
i was just about to ask the same thing - though the figures for that one is less than what Mr koffee dude states
Chris Davey
sunny coast, qld
Re: How much power do you think I will make? Tue, 07 June 2005 09:14 Go to previous messageGo to next message
Don't like speaking for others but to satisfy curiosity I will Smile Yes it was. Speed magazine if anyone wants to have a look. Was a good article.
Re: How much power do you think I will make? Tue, 07 June 2005 09:39 Go to previous message
Once he said E-Boost I had to ask.
Previous Topic:How do you wreck a motor?
Next Topic:Small washer bottle
Current Time: Sun Oct 18 08:01:42 UTC 2026
Total time taken to generate the page: 0.090044021606445 seconds
