Toymods » Tech & Conversions » Wiring Altenator - Help needed
Simon-AE86
Banned user
ADELAIDE - The Drift City
Wiring Altenator - Help needed Mon, 06 June 2005 08:38 Go to next message
I have a fwd alt with a cut plug, Takai has helped me so far by telling me thart the plug that i have has the following wires
White (batt)
Red/Blue (light)
Yellow (sensor)
now im in the process of wiring it into my ae86 body loom, i dont have a wiring diagram atm (was on HDD, which died)
stock alt plug has
Blue/Red
Red/Black
White/Black
I know the White wire on the plug goes to the White/ Black on the body loom but what about the other two!
Re: Wiring Altenator - Help needed Mon, 06 June 2005 11:37 Go to previous messageGo to next message
Hmm all the 4x ae86's i've wired up have not had those colours on the alternator plug.
Are you looking at the original plug, or the plug that used to go into the external voltage reg?
As you need to pick the wires out of the 6 pin(i think 6, or so) plug.
From memory there is a white, yellow & block/yellow wire in there you need.
Now i'm also bit confused about those colours you have on the alternator. The 16v 4ages i've done dont have blue/red.
Anyhow, usually there is a label or ingraving telling you the pins on the alternator.
There should be IG, S and L . As well as the big arse white charge wire that goes directly to battery.
IG (normally black/yellow) goes to ignition + (you'll find this in the old external reg plug, check with multimeter to be sure).
S - (normally white) goes to B+ (can just connect to the big arse charge wire.
L - charge light. wire in ext. alt. plug, white or yellow i'm quite sure.
Joel
[Updated on: Mon, 06 June 2005 11:38]
sideshow
Re: Wiring Altenator - Help needed Mon, 06 June 2005 11:42 Go to previous messageGo to next message
an ae86 has an external votltage reg
the new alt i think has an internal reg
usually white is battery
reb/blue is ignition
yellow is light
Simon-AE86
Banned user
Re: Wiring Altenator - Help needed Mon, 06 June 2005 11:54 Go to previous messageGo to next message
what colour is the Igniton wire and the charge light wire on the ae86 loom that is the thing im not sure about.
Simon
sideshow
Re: Wiring Altenator - Help needed Mon, 06 June 2005 11:57 Go to previous messageGo to next message
well once u cut out all the crap thats not neded
ign is black n yellow
light is yellow
white is bat
Simon-AE86
Banned user
Re: Wiring Altenator - Help needed Mon, 06 June 2005 12:04 Go to previous message
awesome, cheers
Previous Topic:84 celica with 18R-G
Next Topic:ST18X-ST20X into ST162
Current Time: Sat Nov 21 16:44:50 UTC 2026
Total time taken to generate the page: 0.004127025604248 seconds
