Toymods » Tech & Conversions » turbo drain facing up
cri_ag
northern beaches
turbo drain facing up Mon, 06 June 2005 10:43 Go to next message
does it matter if the oil drain outlet of a turbo faces up instead of down? (assume it does) if so how do the guys that use hi-mount manifolds on ca18s etc get away with it?
EVOSTi
cambo
      no
Re: turbo drain facing up Mon, 06 June 2005 10:46 Go to previous messageGo to next message
it definately matters! not only must the drain be facing down, the straighter the better. you want as littls restriction as possible as the only thing returning the oil to the sump is gravity.
4agte
Toronto, Downtown
Re: turbo drain facing up Mon, 06 June 2005 10:47 Go to previous messageGo to next message
yeah no pressure so it needs to be pointing down pointing up will = lotsa mulah to fix turbo
cri_ag
northern beaches
Re: turbo drain facing up Mon, 06 June 2005 10:49 Go to previous messageGo to next message
so the guys that go for hi-mounts (flange facing up on say t25/t28) do they have to rotate the housing?
Salad Fingers
Darwin, Australia
March 2005
Re: turbo drain facing up Mon, 06 June 2005 11:00 Go to previous messageGo to next message
rotate housing/rotate CHRA.. depends which way you look at it I guess.
But yes I had a problem with this on my first turbo setup I ever did. You certainly need as straight as possible return for the oil.
[Updated on: Mon, 06 June 2005 11:02]
cri_ag
northern beaches
Re: turbo drain facing up Mon, 06 June 2005 11:11 Go to previous message
ok no wories, one more thing whats CHRA mean?
Previous Topic:should i just buy as new enigne??
Next Topic:gear down shift problems HELP!!!!!!!!
Current Time: Sat Nov 21 10:04:13 UTC 2026
Total time taken to generate the page: 0.0041429996490479 seconds
