Toymods » Tech & Conversions » Tough LSD for KE70?
1G-GTE KE70
Tough LSD for KE70? Tue, 07 June 2005 03:29 Go to next message
I currently have an Alfa Romeo LSD (4.3:1 gears)
gay 4x108 stud pattern.
I'm after a tough LSD that will be a straight fit for my KE70 and it MUST have a 4x114.3 stud pattern.
what cars would have diffs that I could swap?
Thanks guys.
WHITCHY
Castle Hill
Re: Tough LSD for KE70? Tue, 07 June 2005 03:47 Go to previous messageGo to next message
T Series Diff out of a T-18 should bolt straight up?(Correct me if im wrong) but then be prepared to pay through the ass for an LSD centre! or just go simple and lock it!
or source the diff out of an JDM AE86, same as T-18, but disk instead of drum and standard LSD in most. probaly still pay about 2K for one of them!
September_Squall
Melbourne, Australia
March 2005
Re: Tough LSD for KE70? Tue, 07 June 2005 04:38 Go to previous messageGo to next message
Logic error; He's running a 1G-GTE with T04 and asked for a strong diff.
Possibilities: R31 Borg Warner is too wide but standard 4x114.3 and LSD available. Hilux differential is often used and pretty unbreakable (haven't you seen the ads lol) but not 4x114.3, you can use old Ford pattern rims on the back or convert back to 4 stud with a bit of mucking around.
[Updated on: Tue, 07 June 2005 04:41]
1G-GTE KE70
Re: Tough LSD for KE70? Tue, 07 June 2005 07:16 Go to previous messageGo to next message
yeah well as for the stud pattern. it just has to be one that there are actually wheels for. like 5x114.3 etc. but yeah first preference is strong. second is available stud pattern.
thanks guys.
Re: Tough LSD for KE70? Tue, 07 June 2005 08:17 Go to previous messageGo to next message
Early Hilux. I've written about it before, do a search. Convert the front to 5x114, and use Falcon wheels all round.
MR 1JZ
Re: Tough LSD for KE70? Wed, 08 June 2005 00:08 Go to previous messageGo to next message
1G KE - definitiely go the hilux rear, becuase that also means you will have a huuuge selection of wider aftermarket wheels to run on the rear of the KE...might wanna flare yer guards too Wink
1G-GTE KE70
Re: Tough LSD for KE70? Wed, 08 June 2005 06:50 Go to previous message
approximate cost?
what model hilux?
Wink
Previous Topic:AE92 front strut diameter question
Next Topic:what engine oil should i use in my 18RG
Current Time: Wed Nov 4 03:49:54 UTC 2026
Total time taken to generate the page: 0.0054287910461426 seconds
