Toymods » Tech & Conversions » gze crank angle sensor
s_mitch29
gze crank angle sensor Tue, 07 June 2005 08:00 Go to next message
hey i was wondering if anyone knew how to find the first tooth and line the crank angle sensor up properly to get the timing right
any help would be heaps good
mitch
sideshow
Re: gze crank angle sensor Tue, 07 June 2005 09:34 Go to previous messageGo to next message
theyre a pain to find otu
just turn one tooth then start
if it runs ok its right
if not turn one more tooth hehe
EVOSTi
cambo
      no
Re: gze crank angle sensor Tue, 07 June 2005 09:48 Go to previous messageGo to next message
haha yeah thats the way i did it. best to mark it up before you take it out, but you learn the hard way.
s_mitch29
Re: gze crank angle sensor Tue, 07 June 2005 11:35 Go to previous messageGo to next message
thanks guys i done that just before i got your replys and yeah i got it second go Very Happy
car starts and idle at about 1000rpm but when it hits 50 degrees it wont idle at all it just drops right off and engine dies!!!
any ideas ???
[Updated on: Tue, 07 June 2005 11:36]
sideshow
Re: gze crank angle sensor Tue, 07 June 2005 11:49 Go to previous messageGo to next message
might have to move to melbourne
never gets hot there so car wont hit 50 degrees heheheeh
couldbe idle motor blocked
what car is the gze in
might be wired wrong
might be vacuum or idle hoses wrong
s_mitch29
Re: gze crank angle sensor Tue, 07 June 2005 11:56 Go to previous messageGo to next message
haha maybe so!
its actually gte and its in a ke30
pretty sure that everything is wired right and vacuums right
but can never be positive
could it just be the ecu??? its running microtech ltx-8
sideshow
Re: gze crank angle sensor Tue, 07 June 2005 12:10 Go to previous message
somethin m,ust happen at 50 degrees
either the tune is wrong
maybe the cold start drops off at 50 so u might have to crack throttle open bit more to get more air in at idle
do u haveidle screw try adjusting it when warm
Previous Topic:removing overspray on headlights and parker and paint (got some crappy paint on the good paint)
Next Topic:1G-GTE revision 3 spun bearing!!!!
Current Time: Tue Jun 9 07:55:06 UTC 2026
Total time taken to generate the page: 0.0061590671539307 seconds
