Toymods » Tech & Conversions » a blown head gasket or not that is the question?
jackel
icon9.gif  a blown head gasket or not that is the question? Tue, 07 June 2005 08:26 Go to next message
ok i dunno if i've blown my head gasket, the pic below shows the choc milk crap on my radiator cap. The coolent is nice and green and there are no bubbles showing when the car is running
http://img206.echo.cx/img206/2108/untitled1si.png
I havn't noticed any power loss but i don't think a 2s-c had any to start with.
I have to fill up my oil abit like once a month.
Is it blown?
i don't really care anyways i got two spare heads and a 3t-gteu coming this weekend hehehe
wilbo666
Re: a blown head gasket or not that is the question? Tue, 07 June 2005 08:34 Go to previous messageGo to next message
That looks all bad. Does it use water? Looks much like a BHG to me.
What does a compression test show?
jackel
Re: a blown head gasket or not that is the question? Tue, 07 June 2005 09:54 Go to previous messageGo to next message
does it use water? you mean coolent?
it uses hardly any top it up every month.
havn't done a compression test yet
sxr01r
The Hills District
Re: a blown head gasket or not that is the question? Tue, 07 June 2005 12:40 Go to previous messageGo to next message
check milk in oil, and bubbles in coolant after car has been running. also you may find a little insight below>
http://forums.toymods.org.au/index.php?t=msg&t h=71129&start=0&rid=4036&S=9fb507964af 2a8ce2275f34f7a2add32
you will find your answers within...hopefully.
Leigh.
jackel
Re: a blown head gasket or not that is the question? Tue, 07 June 2005 13:16 Go to previous messageGo to next message
sxr01r wrote on Tue, 07 June 2005 20:40
Leigh.
the oil looks good, not a sign of milky crap and there are no bubbles in the coolent after it running.
sxr01r
The Hills District
Re: a blown head gasket or not that is the question? Wed, 08 June 2005 07:18 Go to previous messageGo to next message
ok well by the sounds of things its not a BHG, give it a compression test and you will know for sure. clean the gunk off the radiator cap and see if it comes back.
jackel
Re: a blown head gasket or not that is the question? Wed, 08 June 2005 12:38 Go to previous messageGo to next message
yeah i got a compression tester but it's old and can't get it in there.
I've cleaned it off a few times and it appears like once ever two months but the things is, it appears suddenly not builds up slowly.
kingmick
Banned by his request
moved to tamworth
Re: a blown head gasket or not that is the question? Wed, 08 June 2005 12:59 Go to previous messageGo to next message
you have at the minumim oil getting in to the cooling system unless someone added oil instead of coolant!does yours have a cooler for the box in the bottom of the radiator? if not its head gasket. change head gasket and hot flush cooling system and get the radiator flushed and tell them there was oil in the system. also use an oil flush and get the engine at hot idle and then change the oil.you pain, just looked, i had to look at your car on profile to guess at the engine.if k or 4ac you are either using the auto radiator water to water cooler for your oil cooler or you have an auto. so its a leak inside radiator or head gasket.
mick
jackel
Re: a blown head gasket or not that is the question? Wed, 08 June 2005 13:53 Go to previous messageGo to next message
it's got a 2s-c. I'm not gonna do all that until the engine blows up and if that i'm sticking the 3t-gteu in.
But i guess the best thing to do is do a compression test. Smile
kingmick
moved to tamworth
Re: a blown head gasket or not that is the question? Wed, 08 June 2005 14:04 Go to previous messageGo to next message
why the question?
mick
jackel
Re: a blown head gasket or not that is the question? Wed, 08 June 2005 14:42 Go to previous messageGo to next message
just wanted to know if it's on it's way out and how long i got left on the thing. Smile
EldarO
Perth, WA
Re: a blown head gasket or not that is the question? Thu, 09 June 2005 02:09 Go to previous messageGo to next message
ryan, chances are its not BHG
you'd be facing milky oil, oil in your coolant etc.
still, it could be hiding, flush your coolant out and have a look to see if theres any oil in it.
doesnt matter anyway, since you going to put the 3tgte in there... arent you? Evil or Very Mad
Eldar.O.
Re: a blown head gasket or not that is the question? Thu, 09 June 2005 03:38 Go to previous messageGo to next message
someone may have dumped some radiator cleaner or hole fixer in the cooling system in the past?
but chocolate/milky crap is usually emulsified oil.
dumb question: have you recycled any old oil containters as emergency coolant/water containers? i once did this only to end up dumping a whole lot of oil the radiator by accident.
jackel
Re: a blown head gasket or not that is the question? Thu, 09 June 2005 06:42 Go to previous message
i flush the radiator about a year ago, it looked all nice and clean in there.
I don't think i've use a oil bottle to put fluid in.
oh well if any problems occur i'll know what it'll proberly be
Previous Topic:TURBO ON 5K
Next Topic:G series LSD diff oil
Current Time: Fri Nov 20 09:00:33 UTC 2026
Total time taken to generate the page: 0.014740943908691 seconds
