Toymods » Tech & Conversions » 4AGZE Supercharger Upgrade???
menace
June 2005
4AGZE Supercharger Upgrade??? Tue, 07 June 2005 17:04 Go to next message
Hey Guys,
My First Post Razz
Well i might be buying a Corolla. Not sure what the series is called.
This is the shape
http://www.cheshi.com.cn/news/images/2400/2421_1.jpg
Well the car has a Supercharged 4AGZE in it. Running a Microtech ecu.
Well before i buy it i just wanted to know what upgrade's to look at and what limitations it has.
Now first things first does a 1GGZE supercharger fit the 4AGZE?
If so what mods are done. Has anyone done it here?
Well the car seems to have the standard pulley setup on it and also has the factory headers too but with a mandrel bent exhaust. It also has a small front mount intercooler setup...
Would extractors make a major difference?
The car does go alright but suffers at the top end.
What should i look out for with the 4AGZE?
ra23celica
Re: 4AGZE Supercharger Upgrade??? Tue, 07 June 2005 23:25 Go to previous messageGo to next message
No, does not bolt directly on.
You have to custom make the mountings brackets to get the 1G-GZE SC onto a 4A-GZE.
Yes, a couple of people have done it here and they may chime in to this post.
Good extractors will help a bit, but don't expect miracles.
Has the car been dyno tuned/set-up with the Microtech ECU ? If so did they find problems at its top end ?
Use the 'Search' function to find out more info on the 1G-GZE SC and the performance of the 4A-GZE.
4agte
Toronto, Downtown
Re: 4AGZE Supercharger Upgrade??? Tue, 07 June 2005 23:33 Go to previous messageGo to next message
do you know if it is a smallport orbigport gze???
the 1ggze superchargers have been adapted to fit onto this motor but from memory there is issues with making it fit with the standard inlet manifold.
I wouldnt worry about the 1gg supercharger if you want more power and torque buy a nevo 175mm crank pulley this will make a big difference upgrade the front mount to something bigger to allow for the extra heat the pulley will make and it should be quite a quick little rolla you might need a retune on the microtech at this stage.
Main thing to look out for me would be that there isnt exessive oil on the sump or oil leaking onto the headers from the dizzy if it has one.
They are quite a little robust engine if you look after them.
d-shiznit
W.A
Re: 4AGZE Supercharger Upgrade??? Wed, 08 June 2005 00:24 Go to previous messageGo to next message
I'm suprised no one has said it yet...
TURBO!!
Just something cheap like a T25g from a silvia will be a nice upgrade.
Heaps of people on here have turboed their 4agzes, and there is a good article to read in the articles section on this...
By the way I do believe that is an AE82 you have there.
4agte
Toronto, Downtown
Re: 4AGZE Supercharger Upgrade??? Wed, 08 June 2005 02:17 Go to previous messageGo to next message
d-shiznit wrote on Wed, 08 June 2005 10:24
TURBO!!
it is alot cheaper to put a new pulley on than turbo unless you can make up things like exhaust manifolds dump pipes etc.
If you wanna spend about 3k then turbo is better than supercharged the pulleys are what about $500-600 and a retune of the microtech what $400 bigger i/c say something from a 1ggte are what $500 including piping were oly at 1500-a600 buks here pretty much half the cost of a turbo setup.
fatmr2
Re: 4AGZE Supercharger Upgrade??? Wed, 08 June 2005 05:33 Go to previous messageGo to next message
4AGTE Very Happy
Adsport
Perth WA
Re: 4AGZE Supercharger Upgrade??? Wed, 08 June 2005 06:31 Go to previous messageGo to next message
..fitted an sc14 to my aw11 no problems, retains stock intake etc. you can adapt it to run stock cooler also its not that hard, too many people are stuck in a 2D box.
menace
June 2005
Re: 4AGZE Supercharger Upgrade??? Wed, 08 June 2005 09:32 Go to previous messageGo to next message
Hey Guys,
Thanks for the replies.
Not sure of what port type the motor is. I'll take a pic of the engine in the next few days as the car is not far from me...
But i know that the motor is from a MR2...
The dizzie is leaking oil. The owner is going to fix that.
I don't really want to go turbo. The car is enginered with this motor in.
I've been for a cruise in it and it gives wrx's a hard time Smile
The s/c only kicks in a full throttle. Thats how the switch is setup.
I will get power figures from him. I'm not 100% on them atm.
4agte
Toronto, Downtown
Re: 4AGZE Supercharger Upgrade??? Wed, 08 June 2005 10:05 Go to previous messageGo to next message
Adsport wrote on Wed, 08 June 2005 16:31
no 2d box just what ive heard which is exactly what i said b4
4agte
Toronto, Downtown
Re: 4AGZE Supercharger Upgrade??? Wed, 08 June 2005 10:07 Go to previous messageGo to next message
menace wrote on Wed, 08 June 2005 19:32
Hey Guys,
if the motor is from the mr2 then it has lower comp which is better for big boost it should be very quick in a ae82 rolla
extractors cant hurt but the factor extractors arent too bad
you can modify 20v extractors to fit to the gze head
with a nevo 175mm pulley a bigger front mount a new ecu tune the car should be making about 110kw atw kinda ball park figures
[Updated on: Wed, 08 June 2005 10:10]
menace
June 2005
Re: 4AGZE Supercharger Upgrade??? Wed, 15 June 2005 13:01 Go to previous messageGo to next message
Hey Guys,
Went for another drive in the car today.
The car needs a couple of things done to it.
Well the dash need to fixed or replaced. It rattles all over the place. Also i'm gonna have to get a tacho for it as the factory one doesn't work with the 4A conversion..
The drivers seat needs replacing as it noisy... Would any later model seats fit in the AE82?
Also i didn't realise how shithouse the brakes are on the AE82's.
What upgrades do you guys carry out on em?
old_mr2
Re: 4AGZE Supercharger Upgrade??? Wed, 15 June 2005 15:45 Go to previous messageGo to next message
menace wrote on Wed, 15 June 2005 23:01
Hey Guys,
The AW11 seat would probably fit with some minor mods. Great seat! Hugs me well....
b1gb3n
south Melbourne/KL
Re: 4AGZE Supercharger Upgrade??? Thu, 16 June 2005 04:54 Go to previous messageGo to next message
old_mr2 wrote on Thu, 16 June 2005 01:45
Hey Guys,
the ae92 levin seats allows u to adjust how much u want it to "hug" you Very Happy
4agte
Toronto, Downtown
Re: 4AGZE Supercharger Upgrade??? Thu, 16 June 2005 06:03 Go to previous messageGo to next message
i wouldnt be supprised if the aw11 s/c or 88-89 n/a front brakes and calipers would bolt straight on. However it might be alot easier to find some ae82 twin cam front calipers and brakes i think they are bigger than the 4ac ones im not sure tho
kayot1k
Re: 4AGZE Supercharger Upgrade??? Fri, 17 June 2005 03:40 Go to previous messageGo to next message
heres a thought gze is shit
also, is the person your buying the car off a bad lebo ?
noisy rattles, broken seat, leaking oil. just dont buy that car too many hassles.
plus ae82's suck.
[Updated on: Fri, 17 June 2005 03:42]
menace
June 2005
Re: 4AGZE Supercharger Upgrade??? Fri, 17 June 2005 16:33 Go to previous messageGo to next message
Nah it's a dodgy lebo that owns it. The car needs TLC thats for sure...
The car is 20 years old, so that's why i'm not being too picky.
He is going to fix the oil leak.
If i do get it (depends if i sell my pulsar) first thing i'll be doing is fixing the interior up. Maybe the dash just needs a decent look at and the screws looked at.
The drivers seat has to go. Fix the door trims up or get some 2nd hand ones.
Thinking of getting new carpet put in. What's that worth?
Also another question are there short shifters for the AE82's?
I personally don't think AE82's suck. This one might "look" like it does. But i has plenty of power. And for the price he is giving it to me it it's a steal...
It keeps up to standard wrx's and the looks they give you afterwards is priceless... Smile
[Updated on: Fri, 17 June 2005 16:36]
4agte
Toronto, Downtown
Re: 4AGZE Supercharger Upgrade??? Sat, 18 June 2005 01:18 Go to previous messageGo to next message
kayot1k wrote on Fri, 17 June 2005 13:40
im going to give you the benefit of the doubt that you are talking about his gze and not put you in your place
GUN METAL 87 SC
SYDNEY
Re: 4AGZE Supercharger Upgrade??? Mon, 20 June 2005 03:38 Go to previous messageGo to next message
plus ae82's suck.
If you are referring to ALL 4AGZEs and ALL AE82s i seriously think you need to explain why !!
The AE82 twin cams were one of the best cars per $ of the era !
A friend of mine still has an original one, absolutely stock its done 200k is in excellent condition and still drives like new and way way better than any other 1600cc hatch in recent times.
the ride and handling, very zippy and fun to drive, sure its getting dated on the inside but hey...its a 19 year old car !
And dont get me started on the GZE.
To sum up i really dont think its very nice to bag someones car, and certainly not without some sort of explanation.
ke35 - 4AGZE
Re: 4AGZE Supercharger Upgrade??? Mon, 20 June 2005 03:51 Go to previous messageGo to next message
http://img112.echo.cx/img112/4140/p62000081fw.jpg
Rolling Eyes
Re: 4AGZE Supercharger Upgrade??? Mon, 20 June 2005 04:03 Go to previous messageGo to next message
thats nice and compact!!!
why not go a sprintex SC.. much more efficent than the shitty toyota roots style blowers, so you still have heaps of top end (and sucks half the power Smile )
entry cost is high tho, but imho well worth it...
if you buy a car from a dodgy person, you get a dodgy car.. maybe thats why they are offering it so cheap?
horner boy
Re: 4AGZE Supercharger Upgrade??? Mon, 20 June 2005 04:22 Go to previous messageGo to next message
that's a good size turbo. Must have a fair bit of lag?
ke35 - 4AGZE
Re: 4AGZE Supercharger Upgrade??? Mon, 20 June 2005 05:29 Go to previous messageGo to next message
horner boy wrote on Mon, 20 June 2005 14:22
yeah i hope it is, il let you know after i drive it Evil or Very Mad
but hopefully on boost before 4000rpm..
3,500rpm maybe
4agte
Toronto, Downtown
Re: 4AGZE Supercharger Upgrade??? Mon, 20 June 2005 07:22 Go to previous messageGo to next message
it dosent look that big
ke35 - 4AGZE
Re: 4AGZE Supercharger Upgrade??? Mon, 20 June 2005 08:06 Go to previous messageGo to next message
nah it isnt really... Razz
its a GT28RS, should hit boost at or before 3K rpm
4agte
Toronto, Downtown
Re: 4AGZE Supercharger Upgrade??? Mon, 20 June 2005 08:21 Go to previous messageGo to next message
should make some good power
menace
June 2005
Re: 4AGZE Supercharger Upgrade??? Wed, 22 June 2005 06:45 Go to previous messageGo to next message
Well at the moment i'm not 100% on what to do.
Still haven't sold my car so it seems that the rolla will be sold to someone else.
The owner isn't dodgy, it's my mechanic tbh. He bought it off a customer of his that needed the money.
I pretty good mates with him thats why he is giving to me for a good price...
"If" i do get it i'll way up the bang for buck options i have with the rolla...
4agte
Toronto, Downtown
Re: 4AGZE Supercharger Upgrade??? Wed, 22 June 2005 07:04 Go to previous message
sell your car first then shop arround that way your not having to sell you car in a hurry to try and buy something.
Previous Topic:16V 4AGE RWD to 20V head
Next Topic:Urgent: Where is Engine No. on 7MGTE
Current Time: Sun Oct 18 01:24:42 UTC 2026
Total time taken to generate the page: 0.0072770118713379 seconds
