Toymods » Tech & Conversions » FWD gearbox replacement proceedure
corbet01
April 2005
FWD gearbox replacement proceedure Wed, 08 June 2005 00:31 Go to next message
I am about to replace the box in my AE92. the workshop manual says that i have to drop the suspension crossmember to do it. I thourght that i would have to drop the middle menber at the least.
Has anyone replaced a FWD ae92 box with the cross member in place.
If i have to pull it out i may aswell replace the bushings.
How much sould i spend on a clutch (140 hp at the moment)
Ty
sxr01r
The Hills District
Re: FWD gearbox replacement proceedure Wed, 08 June 2005 07:25 Go to previous messageGo to next message
howdy.
i did the box and clutch in my ae92 in feb, got a clutch for i think $140, the last clutch i had was a stockie and it lasted about 70,000kms and i drove it reasonably hard. id suggest going just a stock one unless your after something with a bit more bite. as for pulling out the crossmember you need to definately pull the middle one out, the last time i did the clutch i pulled out the whole crossmember, but the first time i didnt and i only pulled out the middle one. youll need to jack the motor up a bit to get the back engine mount off.
its a fair bit harder to do without pulling the whole crossmember out, however, it is possible.
hope that helps. Leigh
kingmick
Banned by his request
moved to tamworth
Re: FWD gearbox replacement proceedure Wed, 08 June 2005 11:21 Go to previous message
you have 140hp at the wheels? if you not good mechaniclly its going to be a pain as it is if you are! have to support the engine,undo hubs,take gearlever cables off, undo box,take thermo housing of box,undo clutch braket etc etc is a pain of a job compared to rear wheel. if you have 140hp at the wheels from an atmo 4ag get a exedy ceramic button. nice take up with very little shudder at all and can handle the power!should be about the $600 mark i guess retail.
mick
Previous Topic:Rear Suspension in GT4
Next Topic:What's this part in the engine bay? (AE92 - 4A-FC)
Current Time: Thu Nov 19 18:39:05 UTC 2026
Total time taken to generate the page: 0.0060710906982422 seconds
