Classifieds » Parts Wanted » Soarer (UZZ30 or JZZ30) Fuel Pump ECU
Soarer (UZZ30 or JZZ30) Fuel Pump ECU Wed, 08 June 2005 06:41 Go to next message
As title states.
I have no idea what it looks like, but the plug on the loom is about 14pins, only 5 used.
Apparently JZZ30's use them too.
[Updated on: Wed, 08 June 2005 14:01]
Re: Soarer (UZZ30 or JZZ30) Fuel Pump ECU Wed, 08 June 2005 14:03 Go to previous messageGo to next message
Bumpz0r
MacroP
Binningup WA
Re: Soarer (UZZ30 or JZZ30) Fuel Pump ECU Wed, 08 June 2005 15:28 Go to previous messageGo to next message
Hey man,
Try this mob in Welshpool.
Uniparts Aust Pty Ltd
109- 111 Ewing St Welshpool WA 6106
ph: (08) 9351 9061 Auto Parts Recyclers
This is where I got my 1UZ from. 5 bucks the Soarer(Darkgrey/Almost Black duco) it came from is still there. I didn't take this ECU(but nearly every other one) which should be located inside the left C pillar.
Good luck.
EDIT: My EPC shows the JZZ30 unit to be the same as the V8.
[Updated on: Wed, 08 June 2005 15:31]
Re: Soarer (UZZ30 or JZZ30) Fuel Pump ECU Wed, 08 June 2005 15:34 Go to previous messageGo to next message
Cheers Marco
I'm chasing a couple of other leads in Perth at the moment too.
Hopefully someone will come through.
I'll try this place sat morn.
Re: Soarer (UZZ30 or JZZ30) Fuel Pump ECU Thu, 09 June 2005 05:07 Go to previous messageGo to next message
http://cltr.co.douglas.nv.us/images/tothetop.gif
Re: Soarer (UZZ30 or JZZ30) Fuel Pump ECU Sat, 11 June 2005 13:56 Go to previous messageGo to next message
Marco, you're a champ!
Went to UniParts this morning, they still had the black rear cut there (not sure if its the one you were thinking off)
Got the FPC out of it.
I paid through the nose @ $75 but meh, I needed it.
http://conceptual.net.au/~peewee/uza61/fpc_1.jpg
http://conceptual.net.au/~peewee/uza61/fpc_2.jpg
Grant
Newcastle, NSW, Australia
Re: Soarer (UZZ30 or JZZ30) Fuel Pump ECU Mon, 13 June 2005 22:08 Go to previous messageGo to next message
That's cheap considering they are not a common item to get hold of.
Re: Soarer (UZZ30 or JZZ30) Fuel Pump ECU Tue, 14 June 2005 05:43 Go to previous messageGo to next message
I realise its cheap yes, but considering I could have just used an RPM switch to trigger the fuel pump which would have only cost me $30.
Either way I prefer the route I took.
Grant
Re: Soarer (UZZ30 or JZZ30) Fuel Pump ECU Tue, 14 June 2005 05:55 Go to previous messageGo to next message
Is that the Jaycar one?
Re: Soarer (UZZ30 or JZZ30) Fuel Pump ECU Tue, 14 June 2005 06:16 Go to previous message
Nah, I didn't look into Jaycar.
These ones are the ones Sideshow can supply.
Previous Topic:sw20 drivers side rear indicator
Next Topic:wtd 4agze bottom end.
Current Time: Tue Oct 20 15:57:21 UTC 2026
Total time taken to generate the page: 0.0062639713287354 seconds
