Toymods » Tech & Conversions » 3s unknown crankshaft???
rokusan
western queensland
icon4.gif  3s unknown crankshaft??? Wed, 08 June 2005 11:17 Go to next message
help, i have a crankshaft in my 3sgte that has a smaller rear seal size to normal and i can't find a rearmain seal to fit? what is this crankshaft??
EVL-184
June 2005
Re: 3s unknown crankshaft??? Wed, 08 June 2005 22:59 Go to previous messageGo to next message
hahhaha., funny u should say that , when i went to reco my 3SGTE i found that the rear main i bought from repco was to small aswell.., i argued wit them untill the cows came home.....however i found a place close to my work that sells the correct seal, the guys there is a asian and has been in the business for like 40 yrs...drop me a pm , if u want me to get u this seal..
Toobs
Re: 3s unknown crankshaft??? Thu, 09 June 2005 02:02 Go to previous messageGo to next message
Rokusans RMS is too big... EVL-184's is too small... maybe you two should swap seals Very Happy
The crankshafts are probably different between Gen1,2 and 3 or you could have a GTE head on a GE block.
510rob
Vancouver
Re: 3s unknown crankshaft??? Thu, 09 June 2005 19:26 Go to previous messageGo to next message
the 5SFE crank fits into a 3SGE block to give a stroker. the 5SFE rod journals are bigger, and the 5SFE output takes a slightly larger main seal.
take the info with a grain of salt
rokusan
western queensland
Re: 3s unknown crankshaft??? Fri, 10 June 2005 21:19 Go to previous message
yes ge block, have found a landcruiser one to fit, 2f? inside dia. = 84.85mm kit supplied 88.89mm
Previous Topic:How much to install diff??
Next Topic:Aus spec Vs US spec indicator stalks on ae-86
Current Time: Sat Oct 24 03:17:11 UTC 2026
Total time taken to generate the page: 0.01259708404541 seconds
