Toymods » Tech & Conversions » oil temp gauge sender - 4ag(z)e
ae86slaver
oil temp gauge sender - 4ag(z)e Thu, 09 June 2005 03:27 Go to next message
hey guys
trying to install an oil temp gauge. I believe it is electric and has the brass fitting to tap in somewhere
but my question is, this requires a custom fitting directly to oil i would assume?
it doesn't screw into the block/usable on the oil pressure sender?
any help would be appreciated
monkeymajik
Re: oil temp gauge sender - 4ag(z)e Thu, 09 June 2005 03:57 Go to previous message
Couple of ways to do it.
Tap into the sump (requires you to remove sump PITA)
You can also get little sump plug screws that have a hollow centre that you screw the probe into. Greddy make them, not sure if they are the same thread as what you have.
http://www.importbitz.com.au/electronicnew.htm
Alternativly if you have an oil cooler or remote mount oil filter they can also plum in there, with the correct fitting.
Previous Topic:Where to buy custom clutch in melb/vic?
Next Topic:Knocking 2A-C Engine
Current Time: Fri Nov 20 04:57:35 UTC 2026
Total time taken to generate the page: 0.0046980381011963 seconds
