Toymods » Tech & Conversions » ct20 and ct12 wats the diffrence
lilcrash
ipswich queensland
ct20 and ct12 wats the diffrence Thu, 09 June 2005 07:48 Go to next message
wat is the diffrence between these turbos?
will the ct12 fit onto the ct20 manifold??
thanx
also the garret turbo from a 16valve nissan will it fit onto the ct20 manifold??
[Updated on: Thu, 09 June 2005 07:50]
sxr01r
The Hills District
Re: ct20 and ct12 wats the diffrence Thu, 09 June 2005 09:24 Go to previous messageGo to next message
the ct 12 turbos are off a twin turbo 1jz and the ct 20 is off a 3tgte. the ct 20 is larger than the ct 12 and then the ct 26 off the 3sgte is larger than both. if u were to use a ct12 and bolt it onto a ct20 flage then you would be downgrading, unless your using the manifold for a different purpose. simply put, the larger the number, the larger the turbo.
hope that helps. Leigh
lilcrash
ipswich queensland
Re: ct20 and ct12 wats the diffrence Thu, 09 June 2005 09:46 Go to previous messageGo to next message
so basically all ct series turbos are interchangeable??
Mr Revhead
nelson, new zealand
Re: ct20 and ct12 wats the diffrence Thu, 09 June 2005 10:08 Go to previous messageGo to next message
to be exact the ct20 is an old turbo, off the 3tgte i think
the "ct20b" like on the st205 is completly differnt. and an upgrade over the ct26
no, they are not interchangable
ToyT18
Hobart
Re: ct20 and ct12 wats the diffrence Thu, 09 June 2005 11:27 Go to previous messageGo to next message
Is the CT20B the turbo with no markings but a simlilar size to the CT26? i was told the CT20b has ceramic turbine wheel and the CT26 has steel is this right?
Mr Revhead
nelson, new zealand
Re: ct20 and ct12 wats the diffrence Thu, 09 June 2005 20:12 Go to previous messageGo to next message
no the other way around. the "ct20b" is the steel one
the "ct20b" is an internet term its not on the turbo, nor is it used by toyota any where.
Re: ct20 and ct12 wats the diffrence Fri, 10 June 2005 00:05 Go to previous messageGo to next message
sxr01r wrote on Thu, 09 June 2005 17:24
Bzzt. 1GGTE.
Re: ct20 and ct12 wats the diffrence Fri, 10 June 2005 00:48 Go to previous messageGo to next message
ct12a is 1j
Merudo
Central Coast, NSW
February 2005
Re: ct20 and ct12 wats the diffrence Fri, 10 June 2005 00:52 Go to previous message
draven and JCMF beat me to it Laughing
Previous Topic:Indicators work but Hazard Lights dont
Next Topic:flashpoint alarm troubles
Current Time: Wed Oct 14 22:38:43 UTC 2026
Total time taken to generate the page: 0.052594900131226 seconds
