Toymods » Tech & Conversions » 1J into an ST141 Corona
ido09s
1J into an ST141 Corona Sun, 01 December 2002 13:06 Go to next message
Hi guys, being new to these forums i would first say hi......
Also being new to the world of modding a Toyota i would like to ask if anyone has any advice or knows anyone who has performed the subject conversion.
Secondly what sort of money would be paying for a front cut or engine and box only for a 1J....
look forward to your responses.
Brad
ido09s
Re: 1J into an ST141 Corona Mon, 02 December 2002 05:09 Go to previous messageGo to next message
surely someone in here must have some idea of what i need or who to go to......
Re: 1J into an ST141 Corona Mon, 02 December 2002 06:49 Go to previous messageGo to next message
how much would your corona weigh?
'cause if it's under 1100kg, it wont be legal to put the turbo 1jz into it.
a 1jz half cut will set you back as little as $2500, or as much as $4500.
I dont actually know much of anythinga bout coronas, so I cant help you there, although if they start off with a 4 cylinder engine, a 1jz conversion is going to be *hard*
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
icon1.gif  Re: 1J into an ST141 Corona Mon, 02 December 2002 09:00 Go to previous messageGo to next message
Hope you like going in straight lines 'coz you won't want to turn with a 205kg engine out the front of your car.
Why not go the 1G-GTE? It's much better suited to the ST141 and a MUCH easier conversion. At least the 1G will fit in the engine bay without surgery...
If you're really interested, do a search for "1j ra60" or "1j ra65" or "1j ra6x" or something along the same lines. The engine bays are virtually identical.
Re: 1J into an ST141 Corona Mon, 02 December 2002 18:59 Go to previous message
another thing to consider is how quickly the 1jz would mince your corona's diff. I'm guessing a couple of good launches and you'd make diff soup.
your best choices are either find a car better suited to the 1jz (like I did. originally was going to do an RA65 1jz, but went the MA61) or, as Max suggested, put a 1G in. they're a good engine, 210bhp stock, weigh less, smaller, cheaper
of course, Max is a little biased, having a 1G-gte ra60 of his own Smile
hope this helps
Previous Topic:A/C System help needed...
Next Topic:fitting a pod filter to a 2tgeu
Current Time: Mon Nov 23 15:43:54 UTC 2026
Total time taken to generate the page: 0.0062198638916016 seconds
