Toymods » Tech & Conversions » cressida turbo?
project_cress
sunshine coast
June 2005
cressida turbo? Thu, 09 June 2005 23:54 Go to next message
ok complete noob here i have searched and found alot of info, but what i want to know is i have a 85 cressida needs new head so i want to turbo it but unsure wheather to decompress and try turbo the original engine or stick a new one in, now ive looked in half cut mags and apparently there is a turbo cressida in japan, so i assume this is the chaser?? all i want is a simple turbo setup so what would be the best not necciserilly cheapest or fastest just most simple conversion. now im unsure what model and engine mine has but im sure its a 85 now in the mag the engine is a 7mg-det with auto gear box and all wiring would this be a good swap for basic turbo or there are alot of similar from the supra section too all help woud be great!!
Ryan.
Re: cressida turbo? Fri, 10 June 2005 00:58 Go to previous messageGo to next message
If you have a 5M-E DO NOT TURBO IT
Buy a 7MGTE with ecu and loom and 'drop' that in.
dingaling
tas
Re: cressida turbo? Fri, 10 June 2005 00:59 Go to previous messageGo to next message
You'd be off going with a halfcut for sure.
I'm not real cluey on the 85 cressida and what halfcut you'll need
The engine you mention would be a toyota/nissan hybrid Razz which doesn't exist. (7M-GTE)
Again you'll be better off going with a 1JZ-GTE chaser half cut rather then the 7MGTE one. But someone else should be able to fill you in on the details.
project_cress
sunshine coast
June 2005
Re: cressida turbo? Fri, 10 June 2005 01:04 Go to previous messageGo to next message
so the 7MGTE with ecu and loom. is that a basic fit into the 85 model, the mx73 as ive found out? less fuss the better
Merudo
Central Coast, NSW
February 2005
Re: cressida turbo? Fri, 10 June 2005 01:08 Go to previous messageGo to next message
7mgte will fit in on the same mounts as the earlier M series engines
edit: here's the link for rob_RA40's article on M series engines
only the last bits regarding the 5MGE, 6MGE and 7MGE engines should really concern you Smile
http://www4.tpgi.com.au/users/loats/technical/mhis tory/mhistory.html
[Updated on: Fri, 10 June 2005 01:10]
project_cress
sunshine coast
June 2005
Re: cressida turbo? Fri, 10 June 2005 01:11 Go to previous messageGo to next message
excelent because as i mentioned i only want simple turbo with not too much modification to fit with minimul price any one know sumone in the queensland, brisbane area that can help? pref sunshine coast?
Merudo
Central Coast, NSW
February 2005
Re: cressida turbo? Fri, 10 June 2005 01:13 Go to previous messageGo to next message
being an 85, it would have a 5ME though, right?
I remember when I went through the "should i turbo my cressida" phase, but having a 5M-E meant that everyone said exactly what cruzsida did - dont bother turbocharging the 5ME.
project_cress
sunshine coast
June 2005
Re: cressida turbo? Fri, 10 June 2005 01:26 Go to previous messageGo to next message
ok after reading that very informing artical... it seems the 5mg was never factory turbo maybe for a reason... ahem old and shat... and the 7mgte was released in 87-90 and again in 90-92 the deference being 4hp... now i have searched and i can get a 7mgte for $2200 not sure which year dont really care but i assume the older may be better for mine as it is a 85, mx73 but i assume wthout too much drama it can be adapted from a chaser 87-92 to a 85 cressida, now if i am wrng or need to know any more crucial details please inform,
P.S i have a tight budget Very Happy dont we all
well sumone turboed a 5me as in the bottom of the artical into a MS-75 crown lol
[Updated on: Fri, 10 June 2005 01:28]
Skip
Re: cressida turbo? Fri, 10 June 2005 01:41 Go to previous messageGo to next message
Quote:
P.S i have a tight budget dont we all
How tight?
Generally "engine conversion", "easy" and "cheap" cannot be mentioned in the same sentence together.
project_cress
sunshine coast
June 2005
Re: cressida turbo? Fri, 10 June 2005 01:46 Go to previous messageGo to next message
just means i dont have a lump sum of money but will have to save for each phase of the project... unless the bank wants to give me more money Very Happy also front cut 7mgte will come with a stock cooler right?
[Updated on: Fri, 10 June 2005 01:47]
rob_RA40
c'town, NSW
Re: cressida turbo? Fri, 10 June 2005 01:50 Go to previous messageGo to next message
there are a few mistakes in the article, the M-EU was released much earlier than 1979 in Japan.
also the 3M didnt have SU carbs it had mikuni's i think.
project_cress
sunshine coast
June 2005
Re: cressida turbo? Fri, 10 June 2005 01:57 Go to previous messageGo to next message
relevance to my car and this thread is??
[Updated on: Fri, 10 June 2005 01:58]
Chris Davey
sunny coast, qld
Re: cressida turbo? Fri, 10 June 2005 02:34 Go to previous messageGo to next message
I wouldn't really recommend anyone on the sunshine coast for an engine conversion especially if you are on a tight budget. If the 5m --> 7m conversion is as easy as people make it sound then I would do it yourself. Buy a hoist for $300 or you can hire them for aabout $40 for a weekend. Once you get it all mounted, you would have to get it towed to an auto electrician and then exhaust shop.
If you didn't need it until October I would wait because Sideshow usually comes up to QLD and I would recommend him as he specialises in this sort of stuff and as far as I know has a set price, which most auto electricians will not.
good luck
Chris
wilbo666
Re: cressida turbo? Fri, 10 June 2005 02:49 Go to previous messageGo to next message
Skip wrote on Fri, 10 June 2005 11:41
How tight?
yep, its an oxymoron!
EldarO
Perth, WA
Re: cressida turbo? Fri, 10 June 2005 03:38 Go to previous messageGo to next message
engine conversions arent hard,
actually, nothings hard,
people define "hard" by having to think and solve problems.
putting the engine in physically is "easy" and takes a short time.
then, install your loom, sit down with a wiring diagram and start, each wire is colour coded etc.
it just takes a while, its not "hard"
the only thing that sucks is not being able to produce headers, manifold, exhaust pipes, but these can be bought...
Eldar.O.
Merudo
Central Coast, NSW
February 2005
Re: cressida turbo? Fri, 10 June 2005 03:52 Go to previous messageGo to next message
EldarO wrote on Fri, 10 June 2005 13:38
Try telling my old cressida that!
and that was just a cd-player install that I did.... Rolling Eyes
Skip
Re: cressida turbo? Fri, 10 June 2005 05:09 Go to previous message
EldarO wrote on Fri, 10 June 2005 11:38
Eldar.O.
Putting a 1J in my landcruiser was not easy it was hardwork. Putting an engine in physically is not easy cause things foul, things have to be moved and you spend alot of time chasing things around to make it easy as possible. Anyone who has done a conversion will agree with me, it's far from easy even if it has been done a number of times.
Why cant you produce headers, exhaust pipes, manifolds etc? All you need is a welder and some material.
Previous Topic:Engine Code 4AGZE
Next Topic:Indicators work but Hazard Lights dont
Current Time: Fri Nov 20 07:10:42 UTC 2026
Total time taken to generate the page: 0.13728404045105 seconds
