Toymods » General Car Talk » MK3 readers looky here!
2DRFT
April 2005
icon5.gif  MK3 readers looky here! Fri, 10 June 2005 01:01 Go to next message
doing ma70 to jza70 conversion, im snagged on the door plugs are diff, and the rear light plugs are diff, any ideas?... i've looked for pinouts no avail Sad help!!!
lumpy
Adelaide, SA
Re: MK3 readers looky here! Fri, 10 June 2005 01:14 Go to previous messageGo to next message
Why are you mucking around with the door plugs and rear light plugs? They are part of the ma70 body loom - all you need to do (sounds easy but isn't) is mate the jza70 engine loom to the ma70 body loom - wiring in the inputs from dash to ECU and from ECU to TEMS etc.
Or are you putting the jza70 dash in as well?
2DRFT
April 2005
Re: MK3 readers looky here! Fri, 10 June 2005 01:19 Go to previous messageGo to next message
the works, Dash and whole loom are in now, there are 2 door plugs on each side, and only 1 fits, the other one, the MA70 plug is a pyramid shape with 16pins, the JZA70 plugs are a square shape 15pin :S
hamgatan
Re: MK3 readers looky here! Fri, 10 June 2005 01:52 Go to previous messageGo to next message
that sounds like the door lock control relay if its 16 pins..
pin 16 is only a ground as far as i know.. just rewire the JZA loom into it..
Follow this Chart as a Guide -
http://www.cygnusx1.net/supra/library/TSRM/be/BE_052.gif
[Updated on: Fri, 10 June 2005 01:54]
ViPeR_NiPPleX
VIC, Sth Frankston.
Re: MK3 readers looky here! Fri, 10 June 2005 02:32 Go to previous messageGo to next message
I've done this before, just match the wire colours up, only problem is I think there is atleast two wires with the same colour, use a multimeter to confirm what they connect to.
2DRFT
April 2005
Re: MK3 readers looky here! Fri, 10 June 2005 02:39 Go to previous messageGo to next message
yeah i jsut don't want to short the entire loom out, and have a melt down.!!!!
hamgatan
Re: MK3 readers looky here! Fri, 10 June 2005 02:44 Go to previous messageGo to next message
unplug it first obviously before you start soldering..
2DRFT
April 2005
Re: MK3 readers looky here! Fri, 10 June 2005 02:45 Go to previous message
nah no cutting, jsut gonna swap the pins over, to the jza70 plugs.
Previous Topic:Drive Today
Next Topic:Manual jzx90 with speedy wheels in WA
Current Time: Sun Oct 25 22:26:21 UTC 2026
Total time taken to generate the page: 0.0041937828063965 seconds
