Toymods » Tech & Conversions » W50 vs P51 gearbox
smitty1
W50 vs P51 gearbox Fri, 10 June 2005 05:35 Go to next message
How can you tell the difference between a W50 and P51 gearbox. I know that they are both steel case, and that the P51 is close ratio, but how can I tell if the box that I have been given is a P51. I have also been given a diff by the same person, that I believe is a disc brake, live axle F series. Is it possible that they are both out of something like an RA45 GT? If they both came out of the same car, is it more likely to be a P51?
Any help appreciated, Ian.
Re: W50 vs P51 gearbox Fri, 10 June 2005 06:29 Go to previous messageGo to next message
Check the ratios
.... ........R.. ......1......2..... ....3.....4. ...5
W50 -4.039 3.287 2.043 1.394 1.00 0.853
joecoolmk2
Re: W50 vs P51 gearbox Fri, 10 June 2005 13:02 Go to previous messageGo to next message
i'm no pro on a p51, but i know that the w50 is at least 38kg, , is at least a three piece gearbox and the rear cover is aluminium whilst the main section is steel.
cambelt
melb
Re: W50 vs P51 gearbox Fri, 10 June 2005 15:12 Go to previous messageGo to next message
isnt the p51 the box with those funny looking syncros in them, im not sure on the ratios tho
river
Land of Oz
Re: W50 vs P51 gearbox Sat, 11 June 2005 06:10 Go to previous messageGo to next message
You can't tell the difference from the outside. The W50 and the P51 look identical. The P51 uses Porsche type baulk-rings instead of your normal syncros. Furthermore, these rings wear out and when they do you can't get any more. The W50 uses your standard syncro gears and parts are available for it.
You'll have to pull it apart to see if it's a P51 or a W50.
The P51 ratios, for the early GT Celica series, is...
1st - 3.525
2nd - 2.054
3rd - 1.396
4th - 1.000
5th - 0.858
You can purchase W50 boxes with the same ratios and the later Celica GTs and other vehiclesm used the W50 gearbox.
Let us know what it is. If it's a P51 I'll buy it off you 'cos I need one for a genuine early model GT Celica restoration. I could use the W50, but prefer a P51 for originality.
seeyuzz
river
brett_celicacoupe
townsville NQLD
Re: W50 vs P51 gearbox Sat, 11 June 2005 10:48 Go to previous messageGo to next message
while were on the topic of W50's, i was wondering why there is a difference in the bellhousings of tthe 2 W50's i have?? Confused
the first W50 i got come from a 1977 RA40 coupe (LT) and the bellhousing is completly smoothe with no ridges (webbing Confused)
the other W50's ive seen (an RA23 and the one i got) have webbing sort of ridges running across the bellhousing.
what is the go with this Confused
cambelt
melb
Re: W50 vs P51 gearbox Sat, 11 June 2005 14:31 Go to previous messageGo to next message
the p51 is harder 2 shift , looks like the box i have is a p51 , 5 years ago when i pulled it out of the car (because it collapsed a bearing ) i pulled it apart and saw those diff looking syncros but nobody could tell me anything about it at the time , id have 2 dig it out 2 have another look
Lambolica
Northwestern Sydney
Re: W50 vs P51 gearbox Sat, 11 June 2005 23:17 Go to previous messageGo to next message
There is no identifying marks on the outside of the casing, in fact the W50 and P51 casings share the same part numbers from Toyota.
However ther may be a way of finding out if you put a W50 and a P51 next to each other and check things like inside the shifter hole or possibly a minor difference in the main drive shaft into the box. I don't know of this being done. but if you can clarify that the box you have is a P51 and you have access to a W50 I'd like to see them side by side and look for some kind of identifying feature of the P51.
I'd do it myself but the only P51 I know of is in River's car and he won't let me pull it out. Even for the purposes of research. Razz
CelicaRA45
nth ringwood, Victoria
Re: W50 vs P51 gearbox Sun, 12 June 2005 02:34 Go to previous messageGo to next message
my ra45 gt came out with a w50 box they stopped making p51 them at the end of 78
river
Land of Oz
Re: W50 vs P51 gearbox Sun, 12 June 2005 10:42 Go to previous messageGo to next message
Lambolica wrote on Sun, 12 June 2005 09:17
Yeah, I'm a hard man! However, if you think you can fix it, then give me a PM and I may let you have a go Smile
seeyuzz
river
Lambolica
Northwestern Sydney
Re: W50 vs P51 gearbox Sun, 12 June 2005 22:46 Go to previous messageGo to next message
river wrote on Sun, 12 June 2005 20:42
seeyuzz
river
Ok... Pull out P51 --> pull apart internals --> replace with W50 internals --> put back in car.
Fixed...??
I really just want to do a comparison between the 2 boxes sitting side by side. I'm sure there is a difference that can be found externally. I'm quite sure there is a difference between the main shafts
cambelt
melb
Re: W50 vs P51 gearbox Mon, 13 June 2005 03:09 Go to previous messageGo to next message
well i have 2 side by side and the differance i can see is that the 50 has normal gold coulored sncro rings and the 51 had these funny looking ring things c shape sncro rings , other than that they look the same, when the p51 was in the car it was a much firmer shift as in the effort to move the shifter from gear to gear.
Dave
Lambolica
Northwestern Sydney
Re: W50 vs P51 gearbox Mon, 13 June 2005 07:46 Go to previous messageGo to next message
OK here is me showing my comptete lack of knowledge on gear boxes...
Is that externally visable . Ie if I was offered what was claimed to be a P51 could I check this with out major pull aparts. (other than removeing the shifter)?
And is there any difference between the main shafts AT ALL? like the spline being longer of shorter on either one. different shaft diameter? any embossed numbers etc.
Pictures would be brilliant I've been wanting this answered for ages. As I'm looking for one myself.
Simon.
smitty1
Re: W50 vs P51 gearbox Fri, 17 June 2005 08:43 Go to previous messageGo to next message
Thanks for all the info. This is where I show my ignorance of gearboxes, the box is in bits at the moment, apparently so that the teeth could be inspected, but I don't know what normal syncros look like. It doesn't have a bellhousing, and I haven't been able to speak to the bloke that I got it off to find out off him what he knows. Can anyone show me the difference between the two types of syncros?
Thanks, Ian
cambelt
melb
Re: W50 vs P51 gearbox Fri, 17 June 2005 15:16 Go to previous message
find gold parts =w50
Previous Topic:Car Accidnet
Next Topic:4E - FTE RWD
Current Time: Sun Oct 18 21:01:50 UTC 2026
Total time taken to generate the page: 0.0072348117828369 seconds
