Classifieds » Engines, Accessories and other Mechanicals » The Mother of All Fuel Pumps, pt 2
CLG
Perth, Western Australia
The Mother of All Fuel Pumps, pt 2 Fri, 10 June 2005 16:29
1. SX Billet fuel pump model# 18201 (includes aluminium mounting brackets). The 18201 Electric Fuel Pump is the industry leader in it's class. Designed for both EFI and carburetted applications, the 18201 can support up to 1500HP with a single pump. Flow tested to deliver 2.4 GPM at 0 PSI to 0.7 GPM at 90 PSI at 12 volts. The 18201 is well suited for normally carburetted and blow through systems, and is excellent for mid range domestic and import applications.
2. Billet slim-line fuel lilter Model #41002 (includes anodised AN fittings) For Drag Race, Circle Track, and Marine Use. The SX PerformanceT In-Line Fuel Filters are ultra-high flow, advanced filters designed for engines demanding up to 2,000 HP. Each is made from true aircraft-quality materials for extended component life. The in-line design configuration allows a wide choice of mounting locations, ensuring hassle-free installation. Each filter comes complete with mounting hardware
and paper filter element. Our fuel filters are designed to maintain a fuel flow capacity that even exceeds the maximum output of the SX Performance Model 18201 or 18203 Electric Fuel Pump.
3. 4-port adjustable fuel pressure regulator model# 15403 (includes anodised AN fittings).
Everything is brand new and has never had fuel through it. Retail on all those items is around $1500, looking for $850, delivered anywhere in Australia?! Once again - if you have to ask what it's for, it's not for you?!
Previous Topic:20v pistons and rods only done 40,000km
Next Topic:3SGTE and ST185 parts F/S
Current Time: Sun Nov 1 05:45:50 UTC 2026
Total time taken to generate the page: 0.0063929557800293 seconds
