Toymods » Tech & Conversions » Hi guyz heen info on MX83 Diff options..mine broken :(
mx83toy
icon8.gif  Hi guyz heen info on MX83 Diff options..mine broken :( Sun, 01 December 2002 23:52 Go to next message
hi guyz just need to know what diff is a bolt in option that will give me lsd and bigger gears ie about 4.11 or abit bigger....
has to be a bolt in option though
Re: Hi guyz heen info on MX83 Diff options..mine broken :( Mon, 02 December 2002 00:32 Go to previous messageGo to next message
You need a Mk3 Supra diff, they are LSD although I'm not sure if 4.11 gears are easily available. Anyway it's a bolt in proposition for an MX83, the rear end is nearly identical. I think there's a Supra diff in the for sale section at the moment?
You can also use a Hilux LSD centre, but it requires a little more work... they tend to be cheaper though.
Re: Hi guyz heen info on MX83 Diff options..mine broken :( Mon, 02 December 2002 00:58 Go to previous messageGo to next message
MA70 or GZ20 are the likely easy options although I believe there may be some subtle differences making it not quite bolt up.You can however swap the centres around for a small fee at any diff place.
The Hilux swap is a MAJOR PITA - the IRS centre runs big bearings that are specially made for Toyota. Do not attempt this unless you are ready for an expensive, headache riddled experience Shocked ! I am currently doing the reverse (swapping an MA70 IRS LSD into a Hilux carrier) so I am able to use some std catalogue bearings. Cool
biased99
Re: Hi guyz heen info on MX83 Diff options..mine broken :( Mon, 02 December 2002 05:23 Go to previous messageGo to next message
MK3 Supra diff is NOT a bolt-in option for MX83...I know, as I tried to source one for just this purpose, only to have the bloke sourcing the bits compare the two and find out that they are just different enough to preclude a straight swap.
The solution is to use the MK3 internals in an MX83 carrier, which is what I have sitting in my garage, ready to go into mine.
mx83toy
Re: Hi guyz heen info on MX83 Diff options..mine broken :( Mon, 02 December 2002 06:34 Go to previous messageGo to next message
that sounds cool....what gears is it running???
biased99
Re: Hi guyz heen info on MX83 Diff options..mine broken :( Mon, 02 December 2002 21:58 Go to previous messageGo to next message
Ummm...Supra gears? Laughing
Seriously, I have no idea. I'm assuming these are a little shorter (higher numerically) than the Cressida's stock gearing.
Re: Hi guyz heen info on MX83 Diff options..mine broken :( Mon, 02 December 2002 23:08 Go to previous messageGo to next message
The G/MZ20's run 4.3 or 4.5:1 depending on whether they are auto or manual. Supras (MA70s) run a bit taller gearing I think. Someone else might be able to confirm.
mx83toy
Re: Hi guyz heen info on MX83 Diff options..mine broken :( Tue, 03 December 2002 02:13 Go to previous messageGo to next message
drool 4.5's wow
the cressi run 3.9 stock
will those gears fit in the mx83 housing????
Re: Hi guyz heen info on MX83 Diff options..mine broken :( Tue, 03 December 2002 02:41 Go to previous messageGo to next message
To be accurate, I believe it's 4.556:1 Evil or Very Mad - that's probably a bit too short for comfortable highway cruising, although good for the strip!
The gears should be interchangable.
mx83toy
Re: Hi guyz heen info on MX83 Diff options..mine broken :( Tue, 03 December 2002 14:12 Go to previous messageGo to next message
with a decent size set o wheels under the gurds it should be cool hey???
just goot wack the 13's on for the strip Twisted Evil Very Happy
does anyone know how much tyre size puts gearing out???
and...what should i get now...
a g/mz20 is the older soara correct??? simular shape to the cressi???? do they have limmo???
will the gears slot into the cressi housing???
btw diffs are a new venture for me i know nothing of them:)
Re: Hi guyz heen info on MX83 Diff options..mine broken :( Wed, 04 December 2002 00:46 Go to previous messageGo to next message
Old Soarer, yep they come in LSD (I have one but not for sale), and the gears should slot into your Cressida carrier (I believe this is what Biased99 did).
As for gearing changes with different tire sizes, there are 'calculators' for this on the net - I don't know any websites off the top of my head. Just do a search on any search engine.
Cheers Dave.
mx83toy
Re: Hi guyz heen info on MX83 Diff options..mine broken :( Wed, 04 December 2002 01:01 Go to previous messageGo to next message
biased99 will the G A 70 guts fit??? cuz thats what im finding heaps off the soara ones are to hard to find
i dont know if the ga70 is still rgurded as a mk3 Smile i only know some stuff bout the supra's Embarassed
[Updated on: Wed, 04 December 2002 02:26]
biased99
Re: Hi guyz heen info on MX83 Diff options..mine broken :( Wed, 04 December 2002 02:30 Go to previous messageGo to next message
I think you'll find that my internals came from an MA70 Supra...Have a look for one of those.
mx83toy
Re: Hi guyz heen info on MX83 Diff options..mine broken :( Wed, 04 December 2002 02:50 Go to previous messageGo to next message
so ga wont fit you think???? Sad damm!!! i'll look for a ma then
Re: Hi guyz heen info on MX83 Diff options..mine broken :( Wed, 04 December 2002 03:56 Go to previous messageGo to next message
GA70/MA70/JZA70 makes no difference, they're all the same chassis and they all have the same diff type (G series).
mx83toy
Re: Hi guyz heen info on MX83 Diff options..mine broken :( Wed, 04 December 2002 13:24 Go to previous messageGo to next message
guyz im dropping 600 bucks on the ga70 diff this week im going for the 4.5s Smile i so hope this works out!!!
Biggus Dickus
Re: Hi guyz heen info on MX83 Diff options..mine broken :( Thu, 05 December 2002 00:19 Go to previous messageGo to next message
Does a JZZ30 or JZA80 diff fit?
Bugman
Re: Hi guyz heen info on MX83 Diff options..mine broken :( Thu, 05 December 2002 00:29 Go to previous messageGo to next message
not to sure which way you are doing it, but I have a IRS cradle from a a70 supra that i would be willing to part with
mx83toy
Re: Hi guyz heen info on MX83 Diff options..mine broken :( Thu, 05 December 2002 01:00 Go to previous messageGo to next message
i need the a70's guts to put into my mx83 shell is this correct im sure it is???
mx83toy
Re: Hi guyz heen info on MX83 Diff options..mine broken :( Thu, 05 December 2002 02:25 Go to previous messageGo to next message
just put a deposit on a mechanical lsd with 4.551 gears in it for my cressi .... i'm so looking forward to this!!!!!!!!!!!!!!!!
Bugman
Re: Hi guyz heen info on MX83 Diff options..mine broken :( Thu, 05 December 2002 02:52 Go to previous messageGo to next message
just curious as to what it is costing you. as i bought an entire irs cradle as the importer didnt want to pull it apart, wsn cheap though.... also they are damn heavy, silly over weight supras
Re: Hi guyz heen info on MX83 Diff options..mine broken :( Thu, 05 December 2002 03:48 Go to previous messageGo to next message
Dude, seriously, 4.55:1 will be REALLY short! Shocked
mx83toy
Re: Hi guyz heen info on MX83 Diff options..mine broken :( Thu, 05 December 2002 06:40 Go to previous messageGo to next message
with the 3.9s i get 200 in 3rd so not to worried about stepping up to the 4.5's
Bugman
Re: Hi guyz heen info on MX83 Diff options..mine broken :( Thu, 05 December 2002 06:41 Go to previous messageGo to next message
it's a big step though...
I would hate to sit on 130 for 3hours in that.
mx83toy
Re: Hi guyz heen info on MX83 Diff options..mine broken :( Thu, 05 December 2002 06:42 Go to previous messageGo to next message
mine a TRD "MECHANICAL LSD" its a costallotta Smile
wot did yours cost you
Bugman
Re: Hi guyz heen info on MX83 Diff options..mine broken :( Thu, 05 December 2002 06:43 Go to previous messageGo to next message
my one is a torsen with 3.9 gears.
biased99
Re: Hi guyz heen info on MX83 Diff options..mine broken :( Thu, 05 December 2002 12:15 Go to previous messageGo to next message
Just for interest's sake, does anyone know what the ratio for an MA70 LSD is likely to be? As I stated above, I assume it will lower than the standard MX83 item (3.9?)...just curious as to how much lower. (I've no interest in 4.55 ratio "burnout specials" behind the 1UZ Laughing )
Also, as an aside, I'm having some new rims fitted to the car tommorrow (17" CSA Prowlers, as I like the look of 'em). Anyway, the tyre place has some Falken FK451s lying around from someone who couldn't pay for them, and I'm wondering if we'll be able to squeeze these under the Cressida's guards. The sizes?
Front: 235/45ZR17
Rear: 265/40ZR17 Shocked (Like I said, SQUEEZE!)
Rims are 17 x 8s
(Fallback option is Dunlop 3000As in 245 on the rear)
mx83toy
Re: Hi guyz heen info on MX83 Diff options..mine broken :( Thu, 05 December 2002 14:31 Go to previous messageGo to next message
im sure the 265 wont fit man...hey the ratios i was offered were 3.9, 4.23 and 4.551 so i'm geussing thats wot they came with...
it shouldn't be to horrible with the 4.5s in it it does 200 in third with the 3.9's "i've been told" Wink
plus its got a full mechanical trd lsd which is pretty wild
Re: Hi guyz heen info on MX83 Diff options..mine broken :( Fri, 06 December 2002 00:13 Go to previous messageGo to next message
I have some friends with MA70 turbos, and they have a 3.7:1 ratio. They're both autos though; I suspect a manual would have a different ratio. GA70's and JZA70's are probably different again.
Bugman
Re: Hi guyz heen info on MX83 Diff options..mine broken :( Sat, 07 December 2002 02:06 Go to previous messageGo to next message
yeah my GA70 halfcut has G255 on the vin plaque. which means that it was fitted with the 4.556 4 pinion LSD rear end
mx83toy
Re: Hi guyz heen info on MX83 Diff options..mine broken :( Tue, 10 December 2002 14:31 Go to previous messageGo to next message
ITS ALIVE!!!
Re: Hi guyz heen info on MX83 Diff options..mine broken :( Tue, 10 December 2002 20:49 Go to previous message
Good to hear dude. Cool
Previous Topic:t25 4age
Next Topic:MX83 headunit tech specs & cd stacker
Current Time: Fri Nov 20 05:05:38 UTC 2026
Total time taken to generate the page: 0.0095059871673584 seconds
