Toymods » Tech & Conversions » 2tgeu bell housing on 3tgte??
lilcrash
ipswich queensland
2tgeu bell housing on 3tgte?? Sat, 11 June 2005 11:48 Go to next message
will a 2tgeu bell housing fit onto a 3tgte??
CLG
Perth, Western Australia
Re: 2tgeu bell housing on 3tgte?? Sat, 11 June 2005 12:44 Go to previous messageGo to next message
Yes the bellhousing you are currently using with your 2TGEU will fit up too a 3TGTE, however there are other factors to consider.
If you use that bellhousing, you are commited to using the weaker T50 style gearbox, as you probably already know?! What you'll also need to consider is the flywheel and clutch setup too. Dismissing custom clutch setups, you'll need to run the smaller 2TG style flywheel and clutch too, as the input splines for the T50 and the factory fitted W55 are different, requiring the smaller clutch, and the smaller clutch also has a different bolt up PCD than the larger standard style clutch.
lilcrash
ipswich queensland
Re: 2tgeu bell housing on 3tgte?? Sat, 11 June 2005 20:47 Go to previous messageGo to next message
the reason i asked is because i have a w55 behind my 2tgeu.
thanx clint
laterdays
CLG
Re: 2tgeu bell housing on 3tgte?? Sun, 12 June 2005 01:42 Go to previous messageGo to next message
If you definately have a W55 in your car already, you will already have the original 3TGTE bellhousing in there too!
lilcrash
ipswich queensland
Re: 2tgeu bell housing on 3tgte?? Sun, 12 June 2005 07:16 Go to previous message
im not 100% sure that its a w55 but by specs it should be.
thanx again
Previous Topic:Modifying the gas bonnet shocks
Next Topic:AE86 strut/brake upgrade?
Current Time: Sun Oct 18 00:18:24 UTC 2026
Total time taken to generate the page: 0.014228105545044 seconds
