Toymods » Tech & Conversions » damn heavy steering
chrisellis
damn heavy steering Sun, 12 June 2005 01:35 Go to next message
Well im slowly ironing all the bugs out of the sprinter.
Ive rebuilt the steering rack, genuine toyota bush, new rack ends, tie rod ends, rack boots. And plenty of new grease. I have replaced the steering knuckle (2nd hand) the one that connects to the rack. And it was better than my previous one that was very stiff.
However i still have damn heavy steering. Wheel allignment has been performed to orignal specs.
Whiteline springs
There are currently no RCA's on there
Standard front struts
Ive got a couple more ideas on what i will replace/adjust next, but just wanted anyone else's expertise in this area.
So anyone got input on how they fixed the heavy steering in their sprinter?
Regards, Chris
xolent
Re: damn heavy steering Sun, 12 June 2005 01:40 Go to previous messageGo to next message
I had to get stronger. Embarassed
chrisellis
Re: damn heavy steering Sun, 12 June 2005 01:44 Go to previous messageGo to next message
xolent wrote on Sun, 12 June 2005 11:40
lol, ok well ive driven many other sprinters, and mine is still much heavier then those, so its definitly something to do with my car.
note: obviously my car doesent have power steering, and either have others ive driven Razz
Corona RT142
Campbelltown
get new struts, and new tyres that will help, other than that just grin and bear it, put more air in the front tyres. Personally the steering on my rona should be heavier, no ps too and more weight over the front wheels. I find it a breeze to turn the wheel even at parking speed. I have driven my sis's ke70 and would say that her steering would be slitghly hevaier than mine, but her tyres rarely have the proper air in them plus it has worn shocks and springs, but wouldn't really say its heavy.
Maybe its not really that heavy you just need to get used to it.
allencr
tallahassee FL usOFa
Re: damn heavy steering Sun, 12 June 2005 02:09 Go to previous messageGo to next message
wide tires and/or big offset and/or the strut mount bearing.
also "Ive rebuilt the steering rack"
chrisellis
Re: damn heavy steering Sun, 12 June 2005 02:21 Go to previous messageGo to next message
tyres are about 1000k's old and have correct pressure or a little more in them.
rims are only 5.5inch wide. the "i've rebuilt the steering rack" referes to the fact that it was done in a friends garage, with a qualified mechanic pretty much doing all the work for me Very Happy .
I think it might be the uni joint...
xolent
Re: damn heavy steering Sun, 12 June 2005 05:12 Go to previous messageGo to next message
i ran my tires with 37 psi, was a miracle how much of a difference it was.
bubbles
Banned user
Liverpool NSW
Re: damn heavy steering Sun, 12 June 2005 05:48 Go to previous messageGo to next message
xolent wrote on Sun, 12 June 2005 15:12
same here, made a huge difference
Corona RT142
Campbelltown
Re: damn heavy steering Sun, 12 June 2005 05:49 Go to previous messageGo to next message
yeah tyre pressures help alot i run mine at 38psi
ae95
Re: damn heavy steering Sun, 12 June 2005 07:02 Go to previous messageGo to next message
if your running a lot of castor the steering will be heavier.
if your car is lowered u could be experiencing bumpsteer
EMP-2TG
Carlingford, Sydney
Re: damn heavy steering Sun, 12 June 2005 08:24 Go to previous messageGo to next message
caster can be the big killer with steering weight
mine is so damn heavy
Supra8u
Melb
Re: damn heavy steering Sun, 12 June 2005 11:25 Go to previous messageGo to next message
do any sprinters come with power steering? if not can u put in power steering is it better or worse cause its a small car?
FKN16V
NSW, East Coast
Re: damn heavy steering Sun, 12 June 2005 13:57 Go to previous messageGo to next message
Supra8u wrote on Sun, 12 June 2005 21:25
Yes they do have powersteering available, and no i dont think its really worth it.
In the car that i have driven with powersteering it was way to light, i dunno just my preference i guess.
Steve
chrisellis
Re: damn heavy steering Sun, 12 June 2005 23:23 Go to previous messageGo to next message
i run the tyres on 40psi usually, to no avail.
the castor is fine.
im sure its something getting old and stiff, i keep thinking the knuckle, casue when i replaced it, it did heaps (to fix the heavy steering i had), and now its not so good.
Basically u have to turn the car, and then unturn it, like the steering wheel hardly spins back the other way unless u make it.... its that bad.
cannonball
Sydney NSW
Re: damn heavy steering Sun, 12 June 2005 23:37 Go to previous messageGo to next message
The steering should "self centre" (ie come back to centre) by itself under normal driving conditions, so it sounds like something in your steering is seriously constipated. Wider tires/offset will create more drag, making it a little harder to self centre at low speeds, but it should still go straight ahead when you let go of the wheel on the freeway Very Happy . After all, this "self centering", allowing the wheel to spin freely in your hands, is a common technique used in drift.
allencr
Re: damn heavy steering Mon, 13 June 2005 13:08 Go to previous messageGo to next message
the uni-joint would have been very noticable when you removed & replaced the rack, so i don't think you could've missed it.
the ball joint on the bottom, and the bearing in the upper mount are all there is, besides what you've worked on.
i think you've got the rack to pinion gear adjustment too tight.
there is a "pad" that holds the rack against the pinion.
on an old rack with some wear, that has to be adjusted so that the relatively UN-WORN places on either side of center to the end will move freely, and not adjusted for only the center position.
Stefan
Hobart, Tas
Re: damn heavy steering Tue, 14 June 2005 04:10 Go to previous messageGo to next message
Could be caster. RCAs should make a difference if the whiteline springs are lower than stock.
ae86drift
sydney.au
Re: damn heavy steering Tue, 14 June 2005 05:31 Go to previous messageGo to next message
more camber and castor
should do the trick
Stefan
Hobart, Tas
Re: damn heavy steering Tue, 14 June 2005 05:41 Go to previous messageGo to next message
ae86drift wrote on Tue, 14 June 2005 15:31
should do the trick
??? Increasing castor increases steering effort.
ae86drift
sydney.au
Re: damn heavy steering Tue, 14 June 2005 05:50 Go to previous messageGo to next message
seemed to help my car
although my car has quite modified front suspension
chrisellis
Re: damn heavy steering Wed, 15 June 2005 00:52 Go to previous messageGo to next message
allencr wrote on Mon, 13 June 2005 23:08
thanks man, will investigate this on the weekend, thanks for ur help.
Corona RT142
Campbelltown
Re: damn heavy steering Wed, 15 June 2005 12:05 Go to previous message
seems like i spoke too soon, my new wheels are now heavy as on the steering still fine to drive but like ten times stiffer than before, but they are the same width lol. Will go put air in them on the weekend and see what there at but don't look like their flat so wait and see i guess.
Previous Topic:Head Studs For 3TGTE
Next Topic:Can a W58 be bolted to a 4AGE??
Current Time: Fri Oct 30 17:31:42 UTC 2026
Total time taken to generate the page: 0.034441947937012 seconds
