Toymods » Tech & Conversions » 100kw ECU running a 20v
corbet01
April 2005
100kw ECU running a 20v Sun, 12 June 2005 10:32 Go to next message
I am a tight ass uni student again and can not afford to rebuild my GTI 100kw 4age. Has anyone run a 20v on a 100kw ECU and if so how well did it work?
My other question is has anyone put a 16v head onto a 20v bottom end without adjusting the 20v pistons, does this work?
Ty
corbet01
April 2005
Re: 100kw ECU running a 20v Sun, 12 June 2005 10:48 Go to previous messageGo to next message
just realised what i said. I meant to also say that i would replace the quads for the std 100kw plenum and throttle body (realising that i wll have to adapt it)
Ty
kewp
wollongong
Re: 100kw ECU running a 20v Mon, 13 June 2005 01:52 Go to previous messageGo to next message
i can't see it working without a whole lot of hassle. The 100kw ECU can't work the VVT for one thing.
20VBTSECA
May 2005
Re: 100kw ECU running a 20v Mon, 13 June 2005 07:47 Go to previous messageGo to next message
16v head on a 20v bottom end??????????????????????????????????????? what the hell would you want to do that for??? you wont get a block without the head
trd3sg
Sydney Australia
June 2005
Re: 100kw ECU running a 20v Mon, 13 June 2005 07:57 Go to previous messageGo to next message
corbet01 wrote on Sun, 12 June 2005 20:32
Ty
couple of things -
1. You cant 'adjust' pistons as such
2. As said - why the hell would you want to strip a 20v 4age to put a 16v 4age head on? unless ur planning on massive n/a work to go over 220-230hp - i would definitely not recommend it
as for the original question, you CAN technically run the 16v computer but you will run into problems - ignition timing is slightly different plus fuel maps would be more aggresive for the 20v so you MAY run the risk (slightly) of running lean if u do a bit more work to the 20v (ie CAI, exhaust, timing etc)
i personally wouldnt do it -
Sam_Q
S.E suberbs, Vic
Re: 100kw ECU running a 20v Thu, 16 June 2005 11:28 Go to previous messageGo to next message
the 100kw manifold and the 20V one are a very different shape so it might be pretty hard to adapt
b1gb3n
south Melbourne/KL
Re: 100kw ECU running a 20v Fri, 17 June 2005 16:44 Go to previous messageGo to next message
are 20v parts cheaper than 100kw parts?? curious since ur a "tight arse" uni student
corbet01
April 2005
Re: 100kw ECU running a 20v Sat, 18 June 2005 13:08 Go to previous message
Think about it this way.
20v with 40 to 80k on it which you can pick up for $600 or less.
New pistons about $500 if lucky.
20v-- sell quads $200, sell Head $150. keep the rest. As long as the valves clear the pistons who cares for an engine i drive on the street. the performance loss if any (because my current engine is old and probably not 100kw) would probably not be noticed, it is not a track car where i am trying to squeeze the last hp out of it.
Previous Topic:5 stud ra60 front strut
Next Topic:Cold starting problems 100kw 4age
Current Time: Fri Oct 23 04:55:52 UTC 2026
Total time taken to generate the page: 0.10189008712769 seconds
