Toymods » Tech & Conversions » 1g Rattle at low idle
stradlater
Arthurs Creek, Victoria
1g Rattle at low idle Tue, 14 June 2005 02:49 Go to next message
Just the other day, started up the car and there's a GOD AWFUL rattle, kinda like something on the engine is hitting the body, making a banging noise.
Turns out this noise only happens at LOW, very low idle, almost too low to be right idle, and I had a look around and it isn't clearences, it's something either inside the engine or gearbox.
It does sound like it's coming from the back of the engine or the gearbox area, so it does make it slightly hardly to diagnose.
I can confidently say that's it's probably not the engine hitting the body, it's something else. It's a very metallic banging noise, so I'm a little concerned as to what it is.
anyone got any ideas?
Rallystanza
Re: 1g Rattle at low idle Tue, 14 June 2005 03:01 Go to previous messageGo to next message
Exhaust? Dump pipe?
Has on of the engine mounts failed causing the engine to droop anywhere to cause the exhaust to knock on the body?
Jezz
stradlater
Re: 1g Rattle at low idle Tue, 14 June 2005 03:14 Go to previous messageGo to next message
Well worth a look, I don't think it is the case, but I'll have a look.
Grega
melbourne.victoria.austra...
Re: 1g Rattle at low idle Tue, 14 June 2005 06:56 Go to previous messageGo to next message
a mate had this problem with his skyline. turned out to be a bolt (sheared) off in the bellhousing - from when he did his clutch - tap inspection plate maybe see if something rattles back
Re: 1g Rattle at low idle Wed, 15 June 2005 00:54 Go to previous messageGo to next message
Maybe look around the startermotor too.
stradlater
Re: 1g Rattle at low idle Wed, 15 June 2005 03:45 Go to previous messageGo to next message
Ah
you both have very valid ideas
I'll have alook tonight
thanks for the thoughts guys
Grega
Re: 1g Rattle at low idle Thu, 16 June 2005 06:34 Go to previous messageGo to next message
how did you go man?
stradlater
Re: 1g Rattle at low idle Thu, 16 June 2005 07:43 Go to previous message
TOO MUCH BOOOOOOOST..
Hehe
No, but seriously
I haven't had a chance to get aorund to looking at it.
I'm hopefully towing it home on saturday
and then i'll have a good look, and PROBABLY end up pulling the motor out.
You wanna play mechanics on saturday grega?
Wink
Previous Topic:RA65 water leaks!!
Next Topic:Superstrut disc thickness
Current Time: Fri Nov 20 20:34:34 UTC 2026
Total time taken to generate the page: 0.0059120655059814 seconds
