Toymods » Tech & Conversions » ae101 4agze belts --part numbers
bayka
perth
ae101 4agze belts --part numbers Tue, 14 June 2005 04:45 Go to next message
Hey ppl
Im chasing the belt numbers ( compatabilities with 4age) for an ae101 ze.
From searching forums so far ive found :
SC Belt part num : 5PK700 belt
Timing belt Part# 13568-19145 (same as 100kw 4age)
Waterpump Part# 16100-19115 (same as 100kw 4age)
However the belt i want is the one that runs the alternator and aircon compressor direct.
(which inturn runs the powersteering due to another belt between aircon pulley and pwr str pulley)
Is this just a standard 4AGE belt that i can order through coventrys or autopro?? (admittedly ive never changed belts before so ive got no idea)
How long do you rekon i could run the car on battery only if i jump start each time? Does anyone hold a record for that cause im gona try for it...HAHA Smile
inertia
Re: ae101 4agze belts --part numbers Tue, 14 June 2005 06:13 Go to previous messageGo to next message
From my stock ae92 gze...
Aircon to PowerSteering - 4PK625
Crank to Aircon/Alternator - 5PK980
Crank to SuperCharger/Waterpump - 5PK945
Henn
Rosanna, Melb
Re: ae101 4agze belts --part numbers Tue, 14 June 2005 08:20 Go to previous messageGo to next message
Off the top of my head 5pk990 for crank-aircon-alt belt.
But you can wrap a bit of string around them and measure it. The 990 means 990mm long.
Or just ask the guys at the local joint, they'll probably let you take it back and swap it if its the wrong length.
Just try it and see.
Hen
bayka
perth
Re: ae101 4agze belts --part numbers Tue, 14 June 2005 09:06 Go to previous messageGo to next message
Thanks guys, yep i figured it was mm.
Cheers for the help, hopefully ill be able to stop push starting soon
Smile
inertia
Re: ae101 4agze belts --part numbers Wed, 15 June 2005 00:44 Go to previous message
Just remembered...
Autobarn couldn't get the exact belts from their suppliers... so some of them were smaller than what I quoted.
The crank to supercharger/waterpump belt was 5PK940 (5mm shorter).
The AC to Powersteering belt was 4PK620 (5mm shorter).
Both of these shorter belts were bosch... The Crank to A/C was the same as quoted above, 5PK980, this was a Gates brand belt...
Don't forget, the Powersteering belt is a 4PK, not a 5PK like the rest... though double check with your engine... 101 may be different to 92
Previous Topic:how many spline is the input shaft on a w50
Next Topic:Car wont start.. I think its the alternator [MR2 Turbo]
Current Time: Sun Nov 1 13:22:19 UTC 2026
Total time taken to generate the page: 0.013252019882202 seconds
