Toymods » Tech & Conversions » Changing the water pump in a 1JZ
KOFFEE-BLACK
Changing the water pump in a 1JZ Tue, 14 June 2005 05:34 Go to next message
Hi Guys,
what is involved? Can it be done quite easily?
wilbo666
Re: Changing the water pump in a 1JZ Tue, 14 June 2005 05:44 Go to previous messageGo to next message
Depends what you mean?
Do you want to convert you hydraulic fan/waterpump into a waterpump only arrangement?
Or just replace a waterpump only setup, or just replace the complete hydraulic setup?
Chris Davey
sunny coast, qld
Re: Changing the water pump in a 1JZ Tue, 14 June 2005 05:48 Go to previous messageGo to next message
either way there is a fair amount of work. Do a search though, Draven asked the same thing about a month or two ago. Smile
Re: Changing the water pump in a 1JZ Tue, 14 June 2005 06:26 Go to previous messageGo to next message
Easy job but very time-consuming because you have to remove a lot of crap to get at it. If you want to remove the rear section of the pump you even have to take the timing belt and crank pulley off, which is a major PITA. Mad
or 4 or 5, but close, yeah Smile
it's a piece of piss, just quite a few things have to be removed to get to it.
edit: norbie sux
[Updated on: Tue, 14 June 2005 06:32]
Chris Davey
sunny coast, qld
Re: Changing the water pump in a 1JZ Tue, 14 June 2005 06:55 Go to previous message
draven wrote on Tue, 14 June 2005 16:26
Whoops, time flies hey! Razz
Previous Topic:im a new comer
Next Topic:what axles/brakes fit T-18 diff assembly?
Current Time: Wed Oct 28 17:00:28 UTC 2026
Total time taken to generate the page: 0.047948122024536 seconds
