Toymods » Tech & Conversions » Boost Problems
GT4Junkie
May 2005
Boost Problems Tue, 14 June 2005 10:19 Go to next message
Hey all, just wondering if someone knows how to solve this problem for me. Ive got a blitz boost controller and ive set it to .7 bar. Once i turn the car on and has warmed up enough to give it abit of a punch, im able to reach .7 bar easily. After about 10-20 mins of driving the setting that normally reaches .7 bar only ends up reaching about .64 - .66, and to reach .7 again i have to turn the settings up on the controller. Once i get back in the car later on and its cooled down abit, these new settings now reach about .78, and i hve to turn it down again. All this fuckin round with the controller is starting to get to me. Mad Thought maybe it could be because the engine bay gets abit hot, ive built a heat shield and added extra cold air pipping but it still has the same problem. Does anyone know how to go about fixing this??
Any help would be great!!
SW20R
Re: Boost Problems Tue, 14 June 2005 11:34 Go to previous messageGo to next message
your intercooler is probably heatsoaking and what material are you using for your heatshield?
is it still top mount? .05 bar isnt much mate. 1psi
GT4Junkie
May 2005
Re: Boost Problems Tue, 14 June 2005 12:29 Go to previous messageGo to next message
Yea its still the stock top mount. Im using aluminuim, but wen the problem didnt go away i also put some heat tape on it, as a temp solution. Yea i no its not much, jst gettin sick of changin da settings all the time.
Gonna put the battery in the boot in the next few dayz n make a straight air intake n construct a better heat shield. Hopefully moving the filter away from the cooller will make a diff. What material do u recommend to use for a heat shield?
Hunty
Re: Boost Problems Tue, 21 June 2005 04:31 Go to previous messageGo to next message
rubber
4agte
Toronto, Downtown
Re: Boost Problems Tue, 21 June 2005 04:48 Go to previous messageGo to next message
stainless steel is supposed to not be a very good conductor of heat
noogy
Re: Boost Problems Wed, 22 June 2005 04:33 Go to previous messageGo to next message
Aluminium is the 3rd best metallic thermal conductor after silver and copper...
berad
Re: Boost Problems Fri, 24 June 2005 05:22 Go to previous messageGo to next message
im guessing its your top mount... ditch it with w2a or front mount
lilcrash
ipswich queensland
Re: Boost Problems Fri, 24 June 2005 07:35 Go to previous messageGo to next message
if u are swapping to a front mount would u like to sell your top mount. if so how much and where are u located.
thanx
bored
Re: Boost Problems Sun, 26 June 2005 06:02 Go to previous message
Which side of the intercooler are you measuring from?
Which side of the intercooler is the boost controller connected to?
Previous Topic:18R-G cams, which are the best?
Next Topic:3TGTEU - coil/ignitor.
Current Time: Fri Oct 23 13:56:00 UTC 2026
Total time taken to generate the page: 0.011540174484253 seconds
