Toymods » Tech & Conversions » 20v oil level?
JNR 13B
20v oil level? Tue, 14 June 2005 10:43 Go to next message
I just found out that my 20v motor is runing a 4ac dip stick.
after 3days of leaving the oil to run out of my car.
i put 3l of oil in the engine and the dip stick said it full.
i have a feeling that is wrong.
i sure that is using a stock oil sump to.
plaese help guys.
cheer
retro
Re: 20v oil level? Tue, 14 June 2005 12:56 Go to previous messageGo to next message
Find on the net how much the sump is supposed to hold, dump your oil and fill with new oil, then this will give you a little time to source the correct dip stick
[Updated on: Tue, 14 June 2005 12:57]
Re: 20v oil level? Tue, 14 June 2005 14:39 Go to previous messageGo to next message
Which sump and dip stick tube are you using?
JNR 13B
Re: 20v oil level? Wed, 15 June 2005 08:53 Go to previous messageGo to next message
I'm using stock sump.
the dip stick come out of a 4ac.
I have put a total of 3lts in the car.
I have been driving it around for a day or two.
but the dip stick still say full.
I only just found out that it's an 4ac dip stick last night.
Flogbag
Sydney (Campbelltown...!)
Re: 20v oil level? Thu, 16 June 2005 08:00 Go to previous messageGo to next message
i have a 20v with a gze dip stick
i measured from where the oring goes in, to the end of the dipstick in the tube and there the same length this was done as i used a rwd waterpump housing and alt bracket
JNR 13B
Re: 20v oil level? Fri, 17 June 2005 08:05 Go to previous messageGo to next message
20v owner please..........
how much oil do you usually but in your car after the oil change?
becauce i only put a total of 3lts in my car and it said full.
[Updated on: Fri, 17 June 2005 08:06]
JNR 13B
Re: 20v oil level? Fri, 17 June 2005 14:48 Go to previous messageGo to next message
i guess we don't have anyone that drive ae92 20v conversion? Mad
alwyn
Ballarat
April 2005
Re: 20v oil level? Sat, 18 June 2005 04:02 Go to previous messageGo to next message
hi,
Owner of AE93 with 20V
The 20V holds 4.5 litres dry fill.
After oil change min 4.0 litres.
Get onto Toyospares in Bayswater for the correct dipstick
JNR 13B
Re: 20v oil level? Sun, 19 June 2005 10:01 Go to previous messageGo to next message
thank you mate
toof
Re: 20v oil level? Sun, 19 June 2005 11:32 Go to previous message
wouldnt it just be easy to drain it. fill it with the 4.5L then mark on the incorrect dip stick where the level should be ?
Previous Topic:ta22 odd noise.
Next Topic:New blinkers into TA22 (electrical problem)
Current Time: Tue Oct 20 03:59:05 UTC 2026
Total time taken to generate the page: 0.0060369968414307 seconds
