Toymods » Tech & Conversions » disc brakes front end for ke20
nathos
March 2005
disc brakes front end for ke20 Tue, 14 June 2005 12:36 Go to next message
hey every1, i want a good brake upgrade for my ke20 BUT the trick is i was hoping to be able to say with my original 12" wheels?
is this possible, i tried searching i got nothing that helped me out here, as i prefer the look of hub caps and whitewalls, thanks guyz
regards Nath
Re: disc brakes front end for ke20 Wed, 15 June 2005 01:06 Go to previous messageGo to next message
in 12"you can't even use KE30 discs (218mm), you can only use KE10/20 discs (200mm).. of course you may adapt a different caliper and use the KE30 discs, but it's not really worth it.. just go 13"rims Wink and get hubbies and whitewalls for them...
if you must stay 13", i'm afraid you are almost stuck with 200mm discs Sad
nathos
March 2005
Re: disc brakes front end for ke20 Thu, 16 June 2005 12:33 Go to previous messageGo to next message
thanks oldrollas, my ke20 has drums up the front Confused if i want to be able to stop u are basically telling me that i need to get bigger brakes, would ke55 brakes be ok? would i have to get bigger rear drums as well, i doubt i would need discs at the back for a 3k? Confused i was also tryin to think what sort of hubcaps would suit and i dont think ne would Sad its either that or i go get some 13" mazda van rims or what ever fits and get whitewalls, dammit i was lookin forward to having my hubbies Crying or Very Sad
[Updated on: Thu, 16 June 2005 12:33]
rollin_stock
February 2005
Re: disc brakes front end for ke20 Thu, 16 June 2005 13:21 Go to previous messageGo to next message
dude if your ke20 has drums, get some ke20 discs, grab the whole lot, discs, hubs, calipers + backing plates, brake lines and master cylinder if it is larger than yours, and get the proportioning valve from the donor car as well. g/luck
Re: disc brakes front end for ke20 Fri, 17 June 2005 00:50 Go to previous messageGo to next message
zactly, most KE20 have disc...
do you have a transverse leaf suspension setup too? three bolts between the steering arm and the strut? (please check)
ke30-KE70 brakes are 218mm diameter, with later models being a little thicker (12.5 vs 10mm) you will need 13"rims to fit over them (or maybe special 12" Wink )
easiest solution is to find KE20 discs.. you will just need the backing plate, caliper, brake line (better to get new one made up same as the old one), HUBS, and discs. i think the master cylinder is fine if it is unboosted... boosted brakes on these small cars can make it more hairy
fwiw, i've run KE10 master cylinder (unboosted) with KE15, KE20 and KE70 brakes without proportioning valve, and seems to be ok...
with the smaller 200mm discs, the rears could lock first, but not unless you pushed it...
PMP020
January 2005
Re: disc brakes front end for ke20 Sat, 18 June 2005 09:19 Go to previous messageGo to next message
nathos mate
u can just chuk some ke30 or 55 brakes on the front then run some datto 120y 12" wheels with ur hubbys as they have 114 pcd same as ke30s onwards.
the calipers may require a lil bit of grindin but nothing major at all.
cheers scott
styler
Re: disc brakes front end for ke20 Sat, 18 June 2005 12:59 Go to previous messageGo to next message
upsize time on the wheels and the brake upgrades will be a breeze Wink
nathos
March 2005
Re: disc brakes front end for ke20 Mon, 10 October 2005 02:27 Go to previous messageGo to next message
i finally got around to starting this i got ke55 hubs/back plates discs and calipers, from what oldcorollas said in another thread u wont need to upgrade the master cylinder, the only thing im not real happy about and didnt really think through was the different stuff pattern on the front to the rear, ill have 4x110 on the rear and 4x114 on the front, what would i do about my spare :s or would i redrill it andhave both stud patterns? if theres no other way i think i may go try and hunt down some ke20 discs, they were much harder to find... ne thoughts?
Re: disc brakes front end for ke20 Mon, 10 October 2005 04:18 Go to previous message
use your KE20 hubs with the KE55 discs and you keep your stud pattern. i run KE70 discs on KE10 disc hubs.. which are identical to KE20 disc hubs..
Previous Topic:TA22 Struts + Brake upgrade
Next Topic:Wiring Harness
Current Time: Fri Oct 23 04:04:31 UTC 2026
Total time taken to generate the page: 0.0068590641021729 seconds
