Toymods » Tech & Conversions » Superstrut disc thickness
-gt-
Nthn Beaches, Sydney
Superstrut disc thickness Wed, 15 June 2005 00:53 Go to next message
I'm getting some new discs for my superstrut conversion on my AE93 and want to confirm what discs and thicknesses people use?
I've searched and done all the reading, incl that twincam.org thread, which says they're a 25mm thickness, but also to use a DBA disc off an ST185, part no. DBA743. Now that, and the RDA equivalent (RDA7475) are listed as 28mm thickness.
What's the correct thickness, 25mm or 28mm? Is 28mm too thick? There is another RDA disc, RDA7515 which is 24.7mm (?), which disc have you used?
Also, the discs that came on the struts are pretty chewed, what's the minimum thickness i can run if i get them machined?
Help please, i want to get these sorted for this weekend!
GT
Re: Superstrut disc thickness Wed, 15 June 2005 04:01 Go to previous messageGo to next message
How much room is in the calipers?
-gt-
Re: Superstrut disc thickness Wed, 15 June 2005 04:58 Go to previous messageGo to next message
I'll have to wait till tomorrow night till i can measure it.
If i'm measuring room for the disc, won't the pads affect that measurement? ie how much is left in pad thickness, and whether or not the piston is all the way back?
I'd need to put new pads in and see what i can fit, is that what you're saying?
I was hoping someone round here might be able to tell me a part no. that is definately ok to use?
-gt-
Re: Superstrut disc thickness Thu, 16 June 2005 07:29 Go to previous messageGo to next message
Bumpo.
Anyone able to tell me which part no. they've used?
Or if its 25mm or 28mm?
EvilJack
Sutho/Hills NSW
Re: Superstrut disc thickness Thu, 16 June 2005 07:41 Go to previous message
25mm
it will say on the inside of the disc what the lowest diam. is it can go
also go here
http://www.twincam.org/forums/index.php?s=59e70c78 54be0bc71cb28997de46f657&showtopic=1063
all brake options are explained.
Previous Topic:1g Rattle at low idle
Next Topic:GT4 Gearboxes
Current Time: Fri Nov 20 20:56:49 UTC 2026
Total time taken to generate the page: 0.010901927947998 seconds
