Toymods » Tech & Conversions » 4AGE Identification (RWD?)
Gleno28
4AGE Identification (RWD?) Wed, 15 June 2005 02:17 Go to next message
Recently bought a 4AGE that is apparently a genuine RWD AE86 engine and box but info i'm finding suggests otherwise. It's currently set up in RWD, just wondering what it's out of/age etc.
Here's some stuff to help ID:
Eng No. - 4A1083012
Black and Red lettering
7 Rib block on intake side (3 rib on exhaust)
TVIS
AFM
8 Bolt f/wheel
Beige injectors
Yellow computer plugs
22 spline box (T50 - 4AGE?)
clutch on echaust side
From what i can find, it should be a FWD MAP sensored AE92 with 4AC
T50 box, but somehow it has an AFM??
Any ideas?
Glen.
cannonball
Sydney NSW
Re: 4AGE Identification (RWD?) Wed, 15 June 2005 02:37 Go to previous messageGo to next message
Im no expert at this, but what i know is this...
T50 with clutch on exhaust (left)side = ADM
But i am willing to stand corrected on this, i could be full of shite Very Happy
drift86levin
brisvegas
Re: 4AGE Identification (RWD?) Wed, 15 June 2005 04:17 Go to previous messageGo to next message
you have id it pretty well from the looks of it..it could be a bitza?? i know for a fact that all AE86's and 3 rib blocks, and i think they were all map sensored also..does it have DLI? or multiple coils?
drift86levin
brisvegas
Re: 4AGE Identification (RWD?) Wed, 15 June 2005 04:20 Go to previous messageGo to next message
where bout did you get it from, (i'm in brissy) i can have a looksee for ya Smile
Gleno28
Re: 4AGE Identification (RWD?) Wed, 15 June 2005 04:33 Go to previous messageGo to next message
It's got Dizzy and single coil, just curious i guess
I'm over near Wynnum
ae86dave
adelaide
May 2005
Re: 4AGE Identification (RWD?) Thu, 16 June 2005 02:24 Go to previous messageGo to next message
a pic would help<
Rolling Eyes Rolling Eyes Rolling Eyes
Gleno28
Re: 4AGE Identification (RWD?) Thu, 16 June 2005 03:23 Go to previous messageGo to next message
Here's some older pics, any particular area?
http://img99.echo.cx/img99/3066/1000256jpgsmall3jn.th.jpg
http://img292.echo.cx/img292/903/1000257jpgsmall7zj.th.jpg
cannonball
Sydney NSW
Re: 4AGE Identification (RWD?) Thu, 16 June 2005 03:56 Go to previous messageGo to next message
oops Embarassed
[Updated on: Thu, 16 June 2005 04:01]
Gleno28
Re: 4AGE Identification (RWD?) Fri, 17 June 2005 01:46 Go to previous messageGo to next message
I recon it could be an AW11 engine cause it's got an AFM??
Ben Wilson
Re: 4AGE Identification (RWD?) Fri, 17 June 2005 02:30 Go to previous messageGo to next message
For some reason, work has filtered the pictures, if it;s got sideways leads on the distributor cap, then it is probably a mr2 motor.
Gleno28
Re: 4AGE Identification (RWD?) Fri, 17 June 2005 05:12 Go to previous messageGo to next message
That's the one, the leads all point upwards
drift86levin
brisvegas
Re: 4AGE Identification (RWD?) Fri, 17 June 2005 05:21 Go to previous messageGo to next message
they all point up aside from the coil one on any 4age don't they?
GTV AE86
June 2005
Re: 4AGE Identification (RWD?) Fri, 17 June 2005 05:25 Go to previous messageGo to next message
there was one rwd 4age bigport engine that came out with a seven rib block, and it had red lettering on it. They are hard to find but you just might have an authentic one.
Or it is out off another car like a aw11. But it has the tvis intake which was changed when the small ports came in. So I think you have a genuine rwd 7 rib bigport engine.
Japan had the map sensored engines while America and New Zealand had the AFM engines.
[Updated on: Fri, 17 June 2005 05:29]
FKN16V
NSW, East Coast
Re: 4AGE Identification (RWD?) Fri, 17 June 2005 11:30 Go to previous messageGo to next message
Im thinking fwd head cause the water outlet from the head on the inlet cam side, "second pic" looks nothing like my rwd jdm.
Ill see if i have a pic of mine somewhere.
Steve
drift86levin
brisvegas
Re: 4AGE Identification (RWD?) Fri, 17 June 2005 13:48 Go to previous messageGo to next message
i dunno if anyone else has noticed this or not, but it has a FWD/MR2 type cam belt cover..the RWD ae86 ones had no holes in them what so ever..
feral4mr2
Bundaberg, Qld.
Re: 4AGE Identification (RWD?) Fri, 17 June 2005 13:54 Go to previous messageGo to next message
looks just like the 9.4:1 c/r 7 rib t-vis bigport 4age that came out in every 87+ Oz delieverd AW11 that i've seen. the AW11 'red and black' cam writing 4age has the same internals as the early 4agze bar the pistons.
though i do know some of the guys i know in the states have the exact looking engine but their's had the early 4age internals.
the only way you will find out for sure is to remove the sump/splash tray and a big end cap and measure the crank (40mm vs 42mm).
IRA11Y
Club Member
Re: 4AGE Identification (RWD?) Fri, 17 June 2005 14:10 Go to previous messageGo to next message
Well its definately not a rwd version, firstly all rwd units were TVIS , secondly they were all 3 rib blocks, thirdly they were all from factory without exception MAP sensored. And to add the alternator mounting position looks to be incosistent with known rwd ones, the rwd bracket is mounted a little differently.
Gleno28
Re: 4AGE Identification (RWD?) Sat, 18 June 2005 07:56 Go to previous messageGo to next message
cool, thanks peoples, should make it easier for parts etc and to satisfy my curiosity!
Glen.
Xinx
Re: 4AGE Identification (RWD?) Sun, 19 June 2005 07:05 Go to previous message
Gleno28 wrote on Wed, 15 June 2005 12:17
Any ideas?
Glen.
I think I have one these AE92 bigport 4AGE you talking about it got bigport 7ribs Map sensor. Looks exactly the same as your except MAP sensor and distributor cap.
Here is the pic
http://users.tpg.com.au/yendor/4age.jpg
Previous Topic:What spark plugs do you use on your 4A-GTE?
Next Topic:Greddy Emanage Error
Current Time: Sun Oct 18 22:59:59 UTC 2026
Total time taken to generate the page: 0.0061731338500977 seconds
