Toymods » Tech & Conversions » GZE conversion looms connection question
AEXX
GZE conversion looms connection question Wed, 15 June 2005 02:42 Go to next message
I am doing the converion of 101 coil pack GZE converion to sprinter.
Could anyone tell me how to make the rev-meter working?
They say that as is running on coil pack, it got a different way to connect up to the Rev...
Re: GZE conversion looms connection question Wed, 15 June 2005 03:30 Go to previous messageGo to next message
There is a pin out on the ECU for tacho.
sideshow
Re: GZE conversion looms connection question Wed, 15 June 2005 03:35 Go to previous messageGo to next message
i make these signal adapters
which work on most toyotas and most microtechs
are u using a microtech
or the dli converter
AEXX
Re: GZE conversion looms connection question Wed, 15 June 2005 05:10 Go to previous messageGo to next message
I just using ae101 gze stock ECU,
Is your signal adapter can help?
[Updated on: Wed, 15 June 2005 05:12]
Henn
Rosanna, Melb
Re: GZE conversion looms connection question Wed, 15 June 2005 05:23 Go to previous messageGo to next message
If you have a tacho pin out of the ECU then you will need a converter to make the stock tacho work. Stock tacho needs a voltage spike signal from a coil, the ECU gives a 5V square wave.
If the ECU doesn't have a pinout you can tap into the wires running the coils and make your tacho work.
I have circuit diagrams for both circuits at home and I can email them to you or post them here in a couple of days if you like.
Hen
sideshow
Re: GZE conversion looms connection question Wed, 15 June 2005 05:53 Go to previous message
are u using the dli converter cause this is what u need to run 4agze coils on a 20v
if u are then u use my device and run it off the 4agze ignitor
u cant run it off the coil as yr tacho will read half speed
[Updated on: Wed, 15 June 2005 05:54]
Previous Topic:Disabling TVIS
Next Topic:RN90 1JZGTE conversion
Current Time: Mon Nov 23 22:31:28 UTC 2026
Total time taken to generate the page: 0.0054640769958496 seconds
