Classifieds » Parts Wanted » a diff strong enough to handle a sr20 in a ke35
dave_ke30
sydney, the shire
a diff strong enough to handle a sr20 in a ke35 Wed, 15 June 2005 09:31 Go to next message
as title says.. crown, hilux as long as it can fit under the ke35 n handle the power!
dave_ke30
sydney, the shire
Re: a diff strong enough to handle a sr20 in a ke35 Thu, 16 June 2005 07:10 Go to previous messageGo to next message
bump!
toyrota
Re: a diff strong enough to handle a sr20 in a ke35 Thu, 16 June 2005 09:27 Go to previous messageGo to next message
why not look for an alfa 105 diff, they will handle 300hp and more all day.I have one in my ke20(no you can't have it) and it didn't need to be cut down.The 2lt model is lsd and they have disc brakes as a bonus.Worth looking into
Grant
rollin_stock
February 2005
Re: a diff strong enough to handle a sr20 in a ke35 Thu, 16 June 2005 11:24 Go to previous messageGo to next message
toyrota, is there a chance you can measure the diff from hub face to hub face for me? would be an awsome diff to use in the ke10. What does an alfa 105 look like, are they the ones with the twin cam motor an the twin dellortos? are the leaf or coil-link rear?
cheers Sean
faulksy
Re: a diff strong enough to handle a sr20 in a ke35 Thu, 16 June 2005 12:43 Go to previous messageGo to next message
cust down a borg warner 78 series. its alot more common
levinracer
Re: a diff strong enough to handle a sr20 in a ke35 Fri, 17 June 2005 03:27 Go to previous messageGo to next message
alfa 105 is heavy although it is aluminium centre,i have used one in a sprinter before.
lite ace is what i am using now(with a few mods)or have used hilux many times.
crownman
northern beaches
Re: a diff strong enough to handle a sr20 in a ke35 Fri, 17 June 2005 11:22 Go to previous messageGo to next message
Hi what measurement flange to flange do you want? cause I raced a MS112 crown diff with 300hp for ages without problems "F" series has a disc setup and torsen centres are available.Regards crownman.
CLG
Perth, Western Australia
Re: a diff strong enough to handle a sr20 in a ke35 Sat, 18 June 2005 14:47 Go to previous messageGo to next message
I've got a Borg Warner 78 Series diff out of a Skyline here - 28 spline axles (as big as a Ford 9"!), factory disc braked, 4x114.3mm PCD, lots of different ratios available, and LSDs are available for them too. It'll need modifying to install - I've seen one in a KE3x previously, but then again, anything you want to use will need modification! Will PM you.
toyrota
Re: a diff strong enough to handle a sr20 in a ke35 Mon, 20 June 2005 09:20 Go to previous messageGo to next message
My ke20 is at my old mans workshop at the moment as I'm try the finalise the engineering and rego but I should have it home by the weekend, I will try to get a measurement soon
rollin_stock
February 2005
Re: a diff strong enough to handle a sr20 in a ke35 Tue, 21 June 2005 08:02 Go to previous messageGo to next message
Cheers Toyrota, that will be sweet, need the overall width without wheels, hub face to hub face. Sean
dave_ke30
sydney, the shire
Re: a diff strong enough to handle a sr20 in a ke35 Wed, 22 June 2005 09:30 Go to previous messageGo to next message
thanks for the interest but the ke35 is gettin a hilux diff with lsd center put under it.. thanks.
mrk3supra
Sunshine Coast
Re: a diff strong enough to handle a sr20 in a ke35 Sat, 25 June 2005 23:46 Go to previous messageGo to next message
Hey,
I got a Ma70 supra Torsen LSD in perfect condition for $400 plus postage.
Cheers Mick
0408 214762
MX73_drifter
Re: a diff strong enough to handle a sr20 in a ke35 Mon, 27 June 2005 11:22 Go to previous message
my mates got a r200 he wants $300 for it
should be strong enough.
Previous Topic:4age
Next Topic:Mr2 3S-GTE Sump Gasket
Current Time: Sat Nov 21 10:48:32 UTC 2026
Total time taken to generate the page: 0.021000146865845 seconds
